Installation Problem with Alpine to Bose system
Old Jun 25, 2007 | 05:57 PM
nosurf2day's Avatar
nosurf2day
Default Installation Problem with Alpine to Bose system
I am installing my Alpine head unit into my 04. I picked up a wiring harness and spliced all the wires together. It lights up great but no sound? I know i did it right because I installed the same head unit into my eclipse.
Is there something that I need to connect it to the bose system. My roomate says there is a different wiring harness for the bose?
Anyone have some advise?
Old Jun 25, 2007 | 06:14 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
for bose you need to make usre:
1. the remote turn on wire from the headunit (blue with white stripe) is connected to the amp turn on wire from the harness adapter (also blue/white stripe). this turns on the bose amp
2. hook the amp ground wire (i think black with a white stripe?) on the harness adapter to ground, though this may not be neccessary, its a good practice to do it anyway
do those an you should be up and running with sound, though if you didnt use a bose adapter module you may get some annoying HISS in the background at all volume levels.
good luck
b
Old Jun 26, 2007 | 03:46 AM
nosurf2day's Avatar
nosurf2day
Originally Posted by 16psibrick
bose adapter module
b
What the heck it this? Where can I get one, I dont have it.
Old Jun 26, 2007 | 05:40 AM
Swedie3's Avatar
Swedie3
it's called PAC OEM 1. Search for it on eBay. It's an adapter / filter to convert the signal over the stock speaker and subwoofer unit. I just did my install and it's pretty much a straight forward. No issues at all.
Old Jun 26, 2007 | 05:49 AM
nosurf2day's Avatar
nosurf2day
I am looking at it now, so this plugs into my wiring harness from the head unit, then into the car's harness? I dont see where I would splice my head unit wires into it anywhere?
Old Jun 26, 2007 | 06:59 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
the scoscheone works the same way:
http://www.crutchfield.com/S-G6tCnXX...an&i=142C4NN03
b
Old Jun 26, 2007 | 12:26 PM
JFAIR's Avatar
JFAIR
nosurf....the picture that you have is the pac-oem1 that allows you to add addl amps to the stock hu. i installed my alpine hu about 3 days ago. when i get a chance i will pm you w/the three pac items you need.
dcains
Nov 11, 2015 11:36 PM
nanotech
Oct 2, 2015 05:02 AM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
