Install Bose Sub on passenger side?
Old Jul 15, 2007 | 03:59 PM
ESPO 774's Avatar
ESPO 774
Default Install Bose Sub on passenger side?
Wondering how much a pain it would be to wire into the OEM bose system. I have an additional oem bose sub, and amp, and i would like to wire it behind the passenger seat. how would i go about this? what wires to tap, etc? any help appreciated. thanks in advance
Old Jul 15, 2007 | 10:46 PM
Rob10_99's Avatar
Rob10_99
If your going to splice into the feed for the original amp,
I would suggest rewiring the HU to the sub and bridge it from there to the other amp.
Anyone know if you can do this?
I dont think the stock HU has enough power to make it worth it.
The sub isn't that great to begin with, it is decent though.
I'm in the process of getting things together for a 10" eclipse sub
Old Jul 15, 2007 | 10:57 PM
Voboy's Avatar
Voboy
I don't have a bose system but i would guess...
disassemble the sub in the drivers side position...then splice into the wiring (power, inputs, ground, remote turn on)(im not sure how, or if its labeled for you) and run it over to the passenger side and wire it up... do you have a sub mounting plate, and cover?
Old Jul 16, 2007 | 05:53 AM
ESPO 774's Avatar
ESPO 774
i dont have the mounting plate
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
