Need some help with this!!!
Old Aug 6, 2007 | 09:29 AM
CopperZ's Avatar
CopperZ
Default Need some help with this!!!
Just installed some new “Stuff” (can’t revel it yet) and im getting a lot of static and engine wine in my speakers when the car is on and more when im driving. Is there a homemade way t shield the wires from the static. I was thinking trying to use tin foil. But just wanted to ask before I tear it all back down and start tin foiling the crap out my car.
Old Aug 6, 2007 | 09:30 AM
SeanMO's Avatar
SeanMO
If you know where you are picking up the noise from, yes you can surround the wires with foil
Old Aug 6, 2007 | 10:42 AM
350zspl's Avatar
350zspl
if he knows were he is picking up noise from better to re -route wires
Old Aug 6, 2007 | 11:11 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Isn't the general rule for noise to relocate the ground(s)?
Old Aug 6, 2007 | 11:13 AM
THEDUKE's Avatar
THEDUKE
Trying to stop engine noise with foil is like trying to stop a bullet with foil. Do not waste your time and find the type of noise you are getting and fix the problem there. When I say the type of noise is because there are different types, some examples can be ground loops, RCA induced, power wire induced etc.,etc.
Old Aug 9, 2007 | 12:37 AM
CopperZ's Avatar
CopperZ
yea foil did not help. these are rca wires. i cant relocate the wires though. is there another way?
Old Aug 9, 2007 | 06:14 AM
350zspl's Avatar
350zspl
1- check ground on amplifiers , make sure grounds are 18" or less and that paint is removed from point of contact ,and whatever is the largest guage that your negative terminals on amp can have use that gauge not thinner
2- make sure your power wires and trigger wires are running down the opposite side of car than RCA , battery is on passenger side and power wire and trigger wire should be run down passenger side rca and speaker wires should be run down drivers side
3- if you are able take the factory negative ground off underhood battery terminal that is fasten to fender remove i think it is 8 or 6 awg cut new ground same length and fasten in same place making sure no paint is were point of contact is using a 0 awg or if you can't get 0 at least 4 awg but get zero
4- if you did not than replace rca's with a very good set from Stinger 17ft pro 2 or pro 3 interconnects
i am a Stinger dealer if you need help getting o awg wire, rca, 0 awg ring terminals or anything things along these lines PM me
if you do steps 1-4 not only will your noise be gone all these will improve sound
Old Aug 9, 2007 | 08:48 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
IMO, 99 percent of engine whine comes from:
1. poorly routed wires
2. bad ground (loose or too long of a ground wire)
3. band equipment (cheap amps can induce more whine)
the whole thing about having to shield your rcas or get the bet rcas is rubbish, i have done installs with the chepast rcas possible, without an OUNCE of engine noise, as long as its routed right, and the other gear is up to stuff
but if oyu can reveal what oyu have, it would help a bit...
Old Aug 9, 2007 | 01:43 PM
CopperZ's Avatar
CopperZ
OK, its not an amp or subs. (Those are already done) its a box that makes turns stock navi into a TV screen. it does have power wire and a ground but those are tapped right into the stock nav wires. The RCA wires are about 3 ft long running from the center consol to the dash.
Old Aug 9, 2007 | 01:57 PM
DVFlyer's Avatar
DVFlyer
Speed of White
You could try grounding the RCA's negative (barrel) directly to a chassis ground. There is a thread somewhere here (or was it ICIX?) where a member talked about fixing a Pioneer deck whine by doing this.
Old Aug 9, 2007 | 02:00 PM
5ZVP's Avatar
5ZVP
Maybe too obvious but have you check the check the rca cables?
Old Aug 10, 2007 | 04:04 AM
350zspl's Avatar
350zspl
run a new set of rca from back of head unit to amp real quick just connect don't route unless noise goes away
Old Aug 10, 2007 | 06:53 PM
CopperZ's Avatar
CopperZ
I ordered a new Ipod cable (one that plugs into the bottom), maybe the headphone jak is the problem. I checked all the wires and they are fine. If new ipod wires dont workout, then i will try the to shorten the ground. Tnanks!!!!
Old Aug 16, 2007 | 11:35 AM
CopperZ's Avatar
CopperZ
OK, So new Ipod cable did not help! i rewired the ground and cut it in half. Also did not help...
Old Aug 16, 2007 | 12:07 PM
350zspl's Avatar
350zspl
but you are not taking new rca's pulling the HU
pluging new rca into head unit and just run them outside window to amp and plug in to see if rca are bad
this is a fast test 30 minutes
Old Aug 16, 2007 | 12:22 PM
CopperZ's Avatar
CopperZ
Nope Did that test, RCA's are good. Its the box that converts the audio and video signal that needs to be shelded. I just cant find anything that would do the job.
Old Aug 16, 2007 | 12:42 PM
350zspl's Avatar
350zspl
wrap box in dyna mat
Old Aug 16, 2007 | 01:25 PM
DVFlyer's Avatar
DVFlyer
Speed of White
I can't imagine the box needing to be shielded...... but I'm also no EE either. Have you tried grounding that box directly to the battery? Otherwise, perhaps it's a design flaw in the box.
Old Aug 17, 2007 | 06:19 PM
CopperZ's Avatar
CopperZ
No, i havent. I dont know what good that will do though. I also dont think dynomat will do anything its not made for that.
