Custom Stereo Install
Old Aug 8, 2007 | 09:42 PM
virtuoso's Avatar
virtuoso
Default Custom Stereo Install
I'm looking to get a customized stereo installation but something more on the DL. I'm not into the fiberglass neon lit subs, etc etc. Has anyone here done that sort of thing by just replacing the speakers and the sub woofer? If so, can you recommend the perfect 6.5" front & rear speakers and a 10" sub that would fit the stock housing? Oh, and if you live anywhere within the tri-state area in NYC please tell me where I can get that done. Thanks!
Old Aug 8, 2007 | 11:02 PM
DriftMyRide's Avatar
DriftMyRide
I wouldn't mess around with the stock 10" housing. To much work to be done to make it sound right in there.
Old Aug 9, 2007 | 06:20 AM
350zspl's Avatar
350zspl
components
CDT
Rainbow
OZ
RE
you can put a 10" in that location
you may or may not be happy with it
i think it will sound bad
Old Aug 9, 2007 | 06:23 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Search my friend.... No one can recommend the perfect speaker- everyone has different taste. You will also be limited to how much money you want to spend and whether or not you want component speakers or coax type.
Look at Kwame's install thread and get the name of his shop. While his install is very high end, I'm sure they can do simple too.
Old Aug 9, 2007 | 07:38 AM
Kwame's Avatar
Kwame
+1... Most importantly what is your budget?
Old Aug 9, 2007 | 08:46 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
budget is key like everyone said, you can feel free to browse through my site www.simplicityinsound.com, theres gotta be like a dozen Zs or something in there, see if anyhting pops to mind, i speicalize in doing subtle clean installs that can be hidden most of hte time
of coures i woudl like to add DLS to the list of front speaker considerations, along with morel
Old Aug 9, 2007 | 09:15 AM
virtuoso's Avatar
virtuoso
My budget would be a little less than $2500
Old Aug 9, 2007 | 09:27 AM
virtuoso's Avatar
virtuoso
Man, if I lived in Cali I would have definitely gone to your shop. Good work buddy!
Old Aug 9, 2007 | 09:44 AM
Kwame's Avatar
Kwame
I would advise you to spend your money on set of high quality 2-way components, a good multi-channel amp, a good sub and a headunit. In reality this is all you need in a Z. Some of us tend to go overboard .
I would give you advice on what equipment to buy, but I am known to go over budget in things I suggest.
Old Aug 9, 2007 | 09:48 AM
Denver350z's Avatar
Denver350z
Can you do all of that and still afford to get it installed, all for $2500?
Old Aug 9, 2007 | 10:33 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Just rough figures:
Head unit- $300
2 way components- $300
Sub- $200
Amp- $400
TOTAL- $1200.
That leaves $1300 for installation. In reality, install should be less than $500, so you have $800 of "stuff".
Old Aug 9, 2007 | 04:33 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i will say this, a good 40 percentf of the Z installs on my site is 2500 dollars
i would be more than happy to advise you further if you want...just PM me..
but in general:
a decent headunit: $300
DLS iridium 6.2 in kick panels: $950
DLS RA50 5 channel amplifer to run the front comps active and the sub $750
zen enclosure box and two Image dynamics ID10s, $400
wiring etc...100 bucks
get that installed right and tuned right, it would sound REALLY good.
i would be happy to hook you up with the gear as well...infact, i even know someone whos selling a very very slightly used RA50 for a good cost...cough mike cough lol
Old Aug 9, 2007 | 05:04 PM
doug's Avatar
doug
IDQ's right? not ID Max
Old Aug 9, 2007 | 05:52 PM
Mr_Kebo's Avatar
Mr_Kebo
def have to be the IDQS for that price.
Old Aug 9, 2007 | 07:50 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i did say IDs right? i meant ID10s, better suited to the amp anywya
IDQ10sa would be more cash than that
b
Old Aug 10, 2007 | 07:18 AM
DVFlyer's Avatar
DVFlyer
Speed of White
We could probably work out a deal.
Old Aug 10, 2007 | 04:36 PM
doug's Avatar
doug
b
how are the ID10's? is that a recent line.. i don't remember them when i was buying my ID Max's 2 years ago? whats the performance like
Old Aug 10, 2007 | 07:45 PM
azula's Avatar
azula
the stock location is a lil bit of task to fit in, it can be done though....just be prepared to spend a couple extra bucks....
Old Aug 10, 2007 | 08:06 PM
TurboTrey's Avatar
TurboTrey
I don't think it would be hard at all for a good installer to make a box that would fit in the stock location.
Old Aug 11, 2007 | 08:37 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
the ID is not bad, most efficient out of all ID subs, good SQ (about i would say 90 percent of ithe IDQ) with acutally a bit more output than the IDQ, and cheaper than IDQ or IDmax line
b
2ndchanceZ
Oct 26, 2015 08:03 PM
