Help me understand optimal subwoofer wiring & setup for 4ch amp
I am working on building my system for the Z and had a few questions when it comes to subwoofer and amplifier specs. I have a Memphis M Class amp with the following specs:
75w x 4 @ 4 ohm
115w x 4 @ 2 ohm
230w x 2 @ 4 ohms bridged
I plan on using this amp to power a set of door components and bridge the rear channels to power one 10" sub. There are a few things I don't understand.
Thanks in advance
75w x 4 @ 4 ohm
115w x 4 @ 2 ohm
- Is there any benefit to a DVC sub in this situation? If so, what?
- What about a 2ohm or 4ohm subwoofer? Will that make a difference?
- Is it worth it to find components that are stable to 2ohms so I can run 115w instead of 75w to the front?
Thanks in advance
You want to find either a single 4-ohm voice coil sub or a dual 2-ohm voice coil sub and wire it in series to show the amp a 4-ohm load. Unless it specifically says on the amp or in the amp's manual it most likely can't handle (safely) a 2-ohm load bridged. Dual or single, there really isn't much of an advantage at this power level. The dual voice coil subs can handle more power per sub which is their main advantage. You run subs mono anyway, so it's not like you need a left and right sub channel.
2-ohm components would be tough to find. Stick with the 4-ohm.....with only 230 watts to the sub, 115 watts per side for your components would be overkill and you would have to turn them down anyway to balance the sound with the sub. 75 for components and 230 to the sub is a pretty good balance.
ARC Audio is some top notch stuff. Their subs are very solid. And although not the loudest out there, they are very clean and accurate.
Thanks man, you rock. You answered all of my questions, plus a couple I didn't even ask all in one post.
350Z_Al
Oct 29, 2020 07:44 PM
