Bad Sub Vibrations
Old Aug 26, 2007 | 04:54 PM
psowacki's Avatar
psowacki
Default Bad Sub Vibrations
I put a aftermarket sub behind the driver side seat and it vibrates to much - is there any way of getting rid of that - i really dont want to put the sub in the back of the car
Old Aug 26, 2007 | 04:59 PM
StreetOC192's Avatar
StreetOC192
Well, to fix the vibrating, you can use a lot of sound damping. However, look around this forum for a while and use the search function. You may soon find out that using the stock sub location may not yield the greatest results. It's not a sealed enclosure and it takes a LOT of work to seal it air tight. Good luck!
Old Aug 26, 2007 | 05:18 PM
Sean's Avatar
Sean
Play The Beach Boys greatest hits, see if Good Vibrations fixes it.
Old Aug 26, 2007 | 06:17 PM
TurboTrey's Avatar
TurboTrey
What is vibrating? If it is the panel it is on surround the edges with dynamat.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
