Need help on amp sub ohms again.
Old Aug 31, 2007 | 01:51 PM
Hybrid90's Avatar
Hybrid90
Default Need help on amp sub ohms again.
Changing my system config and have some questions.
I have an amp that's bridgeable to one channel at 425 X 1 at 4 ohms and have a sub that's 4 ohm DVC laying around. How do I wire both up so that the sub maxes out it's output? OR should I be buying a 2 ohm DVC? Thanks in advance
Old Aug 31, 2007 | 01:55 PM
Ichigo's Avatar
Ichigo
You need a 2 Ohm dual voice coil Sub
If you were using 2 4ohm Dual voice coil subs you could wire them like this to show the amp 4 ohms:
But you said you only have 1
Here's the link to the page I use:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Old Aug 31, 2007 | 03:02 PM
Hybrid90's Avatar
Hybrid90
Yeah that's what I'd figured. I'm just asking cuz someone is selling me the sub for a good price... too bad it's a 4ohm sub though... thanks for the help
Old Aug 31, 2007 | 05:07 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
you either run it at 8oh, or dont run it at all...cuase there is no relaly wat to get 4ohm out of htat sub unless you run just one coil, whcih is not recommended...you need a single 4ohm or dual 2ohm sub
b
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
