navigation wire broken
Old Sep 4, 2007 | 11:48 AM
dunpealhunter's Avatar
dunpealhunter
Default navigation wire broken
Does anyone know where i can get a ribbon or have one made. The 8" white wire ribbon ( like a old computer connector) that connects the navigation motorized door to the circuit board attached to the gauge cluster. Local dealerships are telling me they do not sell it separately and that I need to buy the entire door and cluster... at a tune of $350.00. Any help would be much appreciated..... thanks Ed
Old Sep 4, 2007 | 06:26 PM
TurboTrey's Avatar
TurboTrey
Junkyard?
Old Sep 4, 2007 | 06:33 PM
cheshirecat79's Avatar
cheshirecat79
did it just break or what? If you really wanted to, you could always split the ribbon into its separate wires and crimp/solder the two pieces together. since it's a lot of different connections i'd suggest the soldering.
then again, i dont know exactly what the ribbon looks like so this may not be an option. just a thought.
Old Sep 4, 2007 | 07:11 PM
dunpealhunter
Default It looks like this..
http://img253.imageshack.us/img253/6...ture015az3.jpg
http://img253.imageshack.us/img253/4...ture014hm2.jpg
http://img529.imageshack.us/img529/1...ture011ww9.jpg
I am not to sure about soldiering this, but if I got to spend 300.00 I will try or find someone who can.. the blue end is actually a pad that has exposed connectors kind of like a cellphone batter( their flat)...
I am going to call around to junkyards tomorrow.
Old Sep 7, 2007 | 06:44 AM
dunpealhunter
bump, please any ideas?
Old Sep 7, 2007 | 06:53 AM
cheshirecat79
Ok, it's a different ribbon cable than the kind I was thinking. Most laptops use these kind of ribbon cables to connect things like mice, buttons, keyboards, etc to the motherboard.
You really need to get a replacement. The junkyard is going to be the best bet. I would see if I could find the part number for the ribbon cable itself and look it up somewhere. Perhaps a parts vendor can help you also. Good luck.
Old Sep 7, 2007 | 10:20 AM
dunpealhunter
Thanks for the Idea....Much appreciated
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
