cruiz control
Old Sep 26, 2007 | 09:11 PM
kevin8086's Avatar
kevin8086
Default cruiz control
is there anyway to hook up cc on a base model that didnt come with it? it would be nice to add cc.
Old Sep 27, 2007 | 05:40 AM
KPierson's Avatar
KPierson
With the drive by wire system you will need to get a cc unit that is compatible. Older actuator driven CC systems won't work.
I've personally never seen a DBW compatiable CC system, but I've heard people talk about them, so I assume they exist.
Old Sep 27, 2007 | 08:23 AM
DavesZ#3's Avatar
DavesZ#3
This has got to be one of the most commonly asked questions about a base model. In the 4 years I've been following the Z, I've never seen anybody who has successfully done a CC install on a base Z.
It's not as simple as just adding some electronics - it would have to be something that worked in conjunction with the ECU. Not a trivial task! When you consider the small number of base models produced, the market for a CC just isn't there. They'd be expensive if somebody ever did produce one.
Old Sep 27, 2007 | 10:34 AM
cheshirecat79's Avatar
cheshirecat79
I read on some obscure z forum that some member got his cruise to work. He had to add the button, some pedal assembly and had to put in a new ecu from an enthusiast edition along with running some harness stuff. Do a google search and eventually you'll find it.
It was a long time ago and I'm not going to try to find it. If you really need cruise that bad, just trade in your base for an equivalent enthusiast... shouldn't set you back too much. All depends on how much work you want to put into it.
Old Sep 27, 2007 | 11:55 AM
davidz33's Avatar
davidz33
CC can be done, but is it worth it?
I looked into this and the required parts came out to be
1) ecu (there are two different ecu,,, one for base and the other for the rest, I think car toys or turbo toys ?? sell some used ones)
2) pedal switches for clutch and brake
3) steering wheel buttons
As far as I can tell, the above parts are what you need...
Hooking them into the harness? it will be tough
Like I said, this can be done, but ask yourself if this is worth the money and time
Old Sep 27, 2007 | 01:04 PM
cheshirecat79
To my knowledge you shouldn't install used ECUs because they will be paired with the first key they were started with.
Old Sep 27, 2007 | 02:25 PM
DavesZ#3's Avatar
DavesZ#3
There was a guy here who indicated he was going to try it with a kit that physically connected to the gas pedal. My initial impression was that it was dangerous and stupid. Can you imagine what would happen if something stuck or failed?
Old Sep 28, 2007 | 11:13 PM
kevin8086's Avatar
kevin8086
well i dont need it THAT badly, it was just a thought
Old Sep 29, 2007 | 06:32 AM
z350boy's Avatar
z350boy
That is not a major problem. The keys can be recoded. If you need additional keys check this link:
www.streetkeys.com
Old Sep 29, 2007 | 08:14 PM
davidz33's Avatar
davidz33
I had no idea about the key & the ecu relationship
Thanks for the info,,,
The deeper I get into this, the more I think that I don't need CC
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
