QUICK! how to remove the door panels, 2006
Old Oct 2, 2007 | 05:46 PM
r3zon8's Avatar
r3zon8
Default QUICK! how to remove the door panels, 2006
how do i do it?
i looked at the service manual, but i cant seem to figure out how to pop out the window switch??
i got the screw behind the silver door handle...
but theres supposed to be another screw in the pocket of the black window switch assembly..but its not there?!?
remember, 2006!
Old Oct 2, 2007 | 05:50 PM
DVFlyer's Avatar
DVFlyer
Speed of White
I'm not sure if 2006 is the same as 2005, but if so, did you get the screw behind the silver handle you pull on to UNLATCH (behind the black trim piece) the door as well as the one behind the grab handle?
Old Oct 2, 2007 | 05:54 PM
r3zon8's Avatar
r3zon8
i dont think they are the same.
i did the small screw that is covered by a black rubber gromet thing..which is behind the silver door handle(what you use to open the door from the inside)
but theres another screw holding down the switch panel, which is supposed to also be hidden under a black plug and is located in the pocket of the door handle(what you pull on to close the door)
on the 06 theres no pocket..its just an open space that goes all the way down until the lower pocket of the door panel..so do i just pull on the switch panel??
Old Oct 3, 2007 | 05:33 AM
cheshirecat79's Avatar
cheshirecat79
I followed this how-to with my '06 and it went fine.
http://liljerk.morpheus.net/350Z/front_speakers/
Old Oct 3, 2007 | 06:24 AM
r3zon8's Avatar
r3zon8
thanks! got the driver side installed last night.
gonna work on the passenger tonight..
guess it worked out since i am directly comparing stock vs component set while i drive today.
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
