Problem with Xenarc TouchScreen resolution
I have my laptop set up with a 640x480 screen resolution. When I boot the laptop, the Xenarc screen initially indicates a 720x480 resolution, and then a 640x480 resolution. When the system completes its boot sequence, the screen shifts about an inch to the right. I can fix this by resetting the resolution, but it is a pain because I have to do this every time. I thought I had fixed the problem by configuring the laptop to disable the default LCD screen, however this only works sometimes. Any ideas on how to resolve this? Thanks
no clue actually, its only displaying the resolution that the computer is currently giving it, hence the 720x480 at the beginning, thats the resolution of the boot up sequence. it should auto adjust itself, otherwise Id say try giving xenarc tech a call, or just download updated drivers for it; cause I havent found their tech to be that great...
try dl the latest driver for your laptop graphic's card as well. If that don't work try dl a demo version of PowerStrip. depending on your graphic card you can reposition the screen with the laptop. or change the resolution to 720x480 if you wanted to.
