Guru's I need your HELP please.
Old Oct 20, 2007 | 04:38 PM
Nexx's Avatar
Nexx
Default Guru's I need your HELP please.
Ok, I need my tunes tonight but all the sudden both my amps stopped firing. It would very odd for both of them to die like this so I'm hoping its a fuse? Could someone help and point me in the right direction?
Thanks guys!
Old Oct 21, 2007 | 12:21 AM
chadalac350z's Avatar
chadalac350z
1.check fuses under hood by the battery and in the amp. 2. check ground wires to insure proper ground. 3.check all wiring if this does not fix issue, smell amp to see if it smells burnt sounds weird but it smells if its dead or fried.4 if issue still exists check alternator bc both amps cant fry at same time unless alternator fried them.... good luck.. pm me if you need more help/questions.
Old Oct 21, 2007 | 12:31 AM
SuperBlack350z's Avatar
SuperBlack350z
Yeah, check the grounds first of all. Then check fuses. Are both the amps connected together? I doubt it's your alternator.
Chris350z03
Oct 8, 2023 07:19 PM
jetjammer
Sep 6, 2005 08:37 AM
glenngatley
Sep 30, 2003 06:46 AM
