Help!
Old May 28, 2003 | 11:46 PM
Zsilverstone13's Avatar
Zsilverstone13
Question Help!
I just got my new HU(Clarion DXZ935) and the install kits(metra kit and receiver wiring adaptor from Crutchfield). I am still waiting for the center speaker(Clarion SRK5), and still looking for the subwoofer. This is my first time to work on car audio stuff, and I have a few question.
1). The instruction for the receiver wiring adaptor says to connect the ground wire(black) with the ground wire from the receiever to vehicle chassis. I have not taken out the center consol yet, but I am pretty sure that there is no way I can connect these wires to the chasis. What should I do? (I am thinking just to connect the 2 wires together, but just want to be sure)
2). After reading the installation instruction of the HU, I realize after adding the center speaker, there will be just 1 non-fader RCA out. The instruction says this is for subwoofer(non-fader right. The RCA for center speaker is non-fader left), but all the amps or power subs I know have 2 input(left and right)..what to do?
Thanks.
Old May 29, 2003 | 05:13 AM
alphared's Avatar
alphared
theres a big ground cable under the center console in the dash. you can tap into that.
for you center and sub, just buy a Y-splitter (2 female to 1 male) then patch cord the center and the sub into each Y-splitter, and instead of 4 rca, you now have 2. Simple
Old May 29, 2003 | 07:27 AM
Zsilverstone13
alphared,
Thanks, but I am still a little confuse. I have 1 RCA fro SUB, and 1 RCA for center speaker. So I should get the Y-spliter to split the 1 sub RCA into 2 and connect to amp/power sub with it. Is that right?
Thanks,
Old May 29, 2003 | 10:28 AM
alphared's Avatar
alphared
yeah, thats right. i got confused typing you need a y-splitter that has 1 female and 2 males. you can use a regular RCA interconnect (L&R) connect it to the sub and center RCA on the HU, then split it into the amp.
Old May 29, 2003 | 01:01 PM
jeffa's Avatar
jeffa
A lot of amps will allow you to connect only one RCA, and they will bridge both channels internally, eliminating the need for a Y cable.
Old May 29, 2003 | 03:36 PM
Zsilverstone13
Thank y'all. I hope I'll get my center speaker soon, so I can start install my new system.
