ordered a new anp for my sub
Old Oct 31, 2007 | 10:44 AM
350zspl's Avatar
350zspl
Default ordered a new anp for my sub
2007 XXV Maxximus
Hifonics
2-Channel XXV Maxximus
2 x 2000-Watts....RMS @ 4-Ohms
2 x 3500-Watts....RMS @ 2-Ohms
2 x 5000-Watts....RMS @ 1-Ohm
1 x 7000-Watts....Bridged Mono @ 4-Ohms
1 x 10,000-Watts..Bridged Mono @ 2-Ohms
Old Oct 31, 2007 | 10:52 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
holy crap, you better get some kind of upgrade for your alternator if you are going to run anywhere near its full potential, a cap wont help you much with that beast
Old Oct 31, 2007 | 11:12 AM
350zspl's Avatar
350zspl
wrangler 200 amp alt
stinger 1000
stinger 680 x 3
ho alt & 4 batteries
i will be running 7000 watts x 1 bridged @ 4 ohms
Old Oct 31, 2007 | 07:20 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
there you go
what are you hoping to hit?
b
Old Oct 31, 2007 | 07:22 PM
Sean's Avatar
Sean
there you go
b
low flying birds.....when his windows explode.
Old Nov 1, 2007 | 04:24 AM
350zspl's Avatar
350zspl
there you go
b
hoping to hit
145-147 term lab
155-157 audio control
at the moment with the 5000 watts i am running i am doing 143 on the term lab and 153 on the audio control
this amp swap is roughly 75% more power than what i have now
amp is on UPS truck for delivery today
i will break down trunk Friday after work
I will install new amp and re-assemble trunk and tune Saturday
i will be competing Sunday on the AC meter 11-4
i will be competing Saturday on THe TL meter 11/10
keep in mind my scores are quite respectable i use 1 each 12" sub
ONE
Old Nov 1, 2007 | 04:29 AM
StreetOC192's Avatar
StreetOC192
Old Nov 1, 2007 | 05:31 AM
350zspl's Avatar
350zspl
Old Nov 1, 2007 | 05:33 AM
StreetOC192
Originally Posted by 350zspl
Old Nov 1, 2007 | 05:34 AM
350z2go's Avatar
350z2go
^^^^^^ dammmmmmm
Old Nov 1, 2007 | 05:35 AM
StreetOC192
What are the dims on that thing? I'm too lazy to look them up.
Old Nov 1, 2007 | 05:38 AM
350zspl's Avatar
350zspl
25.6"
11.8"
5.3"
plus add 5 " for end caps to length
Old Nov 1, 2007 | 05:40 AM
StreetOC192
25.6"
11.8"
5.3"
And where are you mounting this beast?
Old Nov 1, 2007 | 05:55 AM
350zspl's Avatar
350zspl
going right were this amp is
current amp is RF T40001BD 33" x 12.8" x 3"
Old Nov 1, 2007 | 06:54 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
if you can hit in the mid 150s on AC meter with 1 12", and being a non wall competitor in a Z, that owuld indeed be quite respectable good luck!
b
Old Nov 1, 2007 | 07:02 AM
350zspl's Avatar
350zspl
b
last score was 152.9 on the audio control mic by kickpanel with old amp
should see 2-3 db more with significant jump in power
thanks Bing
Old Nov 1, 2007 | 07:03 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Wholly cr@p! VERY cool.
Have you posted about your alternator before? I would have an interest in hearing about how it fit, pricing, places to buy etc. I know Kwame bought a different brand from SGP that is a direct replacement and I've heard of the wrangler's before but don't recall seeing a thread about an install in a Z.
Old Nov 1, 2007 | 07:14 AM
savvy's Avatar
savvy
what kind of sub are you using?
350zspl's Avatar
350zspl
http://www.wranglernw.com/default.aspx?SkinID=3
200 amp
brings harness
no core charge
$ 550 to $600
Old Nov 1, 2007 | 07:19 AM
350zspl's Avatar
350zspl
at the moment i have 3 ported enclosures that i use
1 = Revolution Design Audio # Alpha V.2 15"
2= Resonant Engineering # MT 12"
3= FI # BTL 12"
all the above 3 have been running 1 ohm at about 4600 watts
i will re-wire the 3 subs in their enclosures to a 4 ohm load , because the new amp does 1 x 7000 @ 4 ohm brideged
but i am buying a 4th sub that i will be able to wire at 1 ohm and use the 10,000 watts the amp can give
new sub will be 1 each revolution design super heavy weight 15" dvc 2 ohm
5000 rms and 30,000 watt burps
