General Alarm and Compustar 2WSS-AS Install Questions...
Old Nov 7, 2007 | 05:50 AM
skn5002's Avatar
skn5002
Default General Alarm and Compustar 2WSS-AS Install Questions...
Hello, I am in the process of installing the compustar 2WSS-AS on my 2003 350z. There are no compustar dealers around my area, so I am attempting this for the first time. I have spent the past few days learning as much as I could online, but I have a few questions and I just want to make sure everything I am about to do is correct. Thanks!
1. For the remote start to work, does anything special have to be done? I was reading about bypassing the immobilizer and clutch switch. Does any of these things have to be done for the 350z with the Compustar 2WSS-AS alarm? If so, how would I go about doing it?
2. The engine sensing wire on the Compustar...does that connect to the Speed sensing wire on the 350z?
3. Do I have to connect the Compustar 'rearm' and 'disarm' wires to anything? or am I okay since it arms and disarms with lock and unlock?
4. Lastly, I was reading "Single pulse on the unlock wire will disarm the alarm without unlocking the doors. Unlock requires a double pulse." So how do I go about doing this?
Old Nov 8, 2007 | 11:28 PM
Vestax's Avatar
Vestax
1. You'll need an immobilizer bypass. There are modules with the key and without the key. Please be responsible and hook up the neutral position output.
2. Use the tach wire.
3. No.
4. You have to program the alarm to do double pulse unlock, otherwise sometimes pressing unlock twice on the alarm works and sometimes doesn't. Since compustar is only meant to be installed by dealers, you might find it hard to program yourself.
burglapfd
Dec 6, 2020 01:04 PM
