Sub not "hitting" right...
Old Jan 24, 2008 | 07:09 AM
playa6tnine's Avatar
playa6tnine
Originally Posted by Z1NONLY
I just skimmed through all the replies. The polarity could be an issue if another driver (large midrange?) in the car is trying to reproduce the same "hit" FQ's as the sub and is out of phase.
But, I wonder if you might have changed the X-over FQ on the amp or other crossover device when you reinstalled the equipment. If the sub is crossed over at 40hz, it might have the effect you are describing. (I don't know if your head unit has a built in sub crossover but if it does, I would check that too. -maybe it defaults to some setting you don’t want.)
Also, a ported box that is incorrectly tuned will do this also.
Sorry if any of this has already been covered.
hmmm i have to check the crossover frequencies now, i know they got out of wack when i was cleaning the amp, so i gotta check it.
Old Jan 24, 2008 | 07:12 AM
StreetOC192's Avatar
StreetOC192
Old Jan 24, 2008 | 08:24 AM
SuperBlack350z's Avatar
SuperBlack350z
get your problem fixed yet?
Old Jan 24, 2008 | 08:49 AM
playa6tnine
na man. I just checked the crossover and its set at 85, which i believe is normal.
i looked at the sub when it hits and it pushes out, so i'm sure its not the polarity. next step (which i will try tonight) will be to take the sub out and check for any leaks. anything in particular to use for sealing up holes in a box?
Old Jan 24, 2008 | 08:55 AM
SuperBlack350z
what type of box are you using? Zenclosure?
Old Jan 24, 2008 | 12:50 PM
Z1NONLY's Avatar
Z1NONLY
If you have an aftermarket head unit, it might have a crossover too.
Old Jan 24, 2008 | 01:14 PM
playa6tnine
Yeah, zenclosure w/ amp rack
35reilly
Sep 28, 2015 07:42 AM
staticfive05
Feb 13, 2009 02:48 PM
Nihsnek
Nov 15, 2008 02:09 PM
ofl0926
Sep 6, 2007 07:59 AM
