Quick Question
Old Feb 14, 2008 | 10:21 AM
Asian Invasian's Avatar
Asian Invasian
Default Quick Question
I am doing my own install on my subwoofers.
I had to buy a LOC because I still have my factory HU. My question is which wires do I merge the loc with? Do I merge the + and - of the loc to the + and - of my front speakers then put it back into the white adapter?
And also which wire do I merge with my Remote turn on wire with?
Old Feb 14, 2008 | 10:59 AM
350zspl's Avatar
350zspl
are you talking about a Line Out Convertor
if yes
you can catch 2 pair of speaker leads to convert to RCA
use your left and right rear speaker leads as they are closest
Old Feb 14, 2008 | 12:41 PM
Asian Invasian
Ok so yes to merging my Front Left and Right speakers to the LOC.
What about my remote turn on wire, what should I hook that to?
Old Feb 14, 2008 | 12:51 PM
350zspl's Avatar
350zspl
easier to catch rear speaker wires than front
go to fuse box
use fuse tap on a fuse that is ignition activated
though low voltage you are still using this trigger as a power wire
all power wires get fused or fire can result
use 18 awg or thicker for trigger and fuse with 1 amp blade fuse
Old Feb 14, 2008 | 12:59 PM
Asian Invasian
This should be behind my dash right hooked up with a bunch of colored wires going into the back so im splicing the rear left and right and connecting it to the LOC then putting it back into that white thing with all the colored wires?
go to fuse box
I dont have any fuse taps, I heard you were supposed to connect the remote turn on lead into the HU instead?
Btw thanks for your help so far I appreciate it.
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
