Wiring for audio
Old Feb 14, 2008 | 06:30 PM
lionheartednyhc's Avatar
lionheartednyhc
Default Wiring for audio
Just bought the USA Spec ipod integration kit. Planning on hooking it up this weekend, but I wanted to store it in the little storage bin behind the passenger seat. What is the easiest way to snake a wire back there?
Thanks
Old Feb 15, 2008 | 05:17 AM
Lsmith9523's Avatar
Lsmith9523
You can run it under your center console,,up through the rear cubby areas,,,you will need to remove the rear small upper cubby you choose to mount in, (they just pop out) drill a small hole in which to route the wire. I hope this helps.
Old Feb 15, 2008 | 07:09 AM
davidpham's Avatar
davidpham
keep in mind that the cables for the usa spec might not reach.
Old Feb 15, 2008 | 10:00 AM
Lsmith9523's Avatar
Lsmith9523
^^^ this is true,,,for I do not use the USA SPEC myself. So, I am not sure the length of cables offered?
Old Feb 15, 2008 | 11:42 AM
lionheartednyhc
Ya I figured. Do you know what type of cable it is, so I can get a longer one?
Old Feb 15, 2008 | 12:55 PM
dirtmcgurt's Avatar
dirtmcgurt
You could mount it underneath your rear cup holder thats what I did recently its. Secure hidden and awesome.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
