Question about mono amp and 2 subs
Old Mar 20, 2008 | 07:32 PM
BEbengali's Avatar
BEbengali
Default Question about mono amp and 2 subs
I haven't dealt with any audio work for over a year, so I forgot a lot of what I knew. I'd really appreciate some help.
I have a Viper D600.1 mono amp from my last car. These are the power ratings (RMS):
Rated Power @ 4 ohm: 275 x 1
Rated Power @ 2 ohm: 400 x 1
Rated Power @ 1 ohm: 600 x 1
I had a dual 2 ohm sub wired in parallel for a 1 ohm load. I would like to use the same amp in my 350Z, and hopefully wire it to two 10 inch subs.
Since it's a mono amp, I am not too familiar with how to wire it to two subwoofers. If I got two dual 2 ohm subs, would I be able to wire them in parallel for a 1 ohm load and use my amp to power each sub with 300 watts @ 1 ohm?
Thanks,
Brian
Old Mar 20, 2008 | 09:38 PM
clarkemtp's Avatar
clarkemtp
No, I don't think you can do what you want with what you have on hand, here's why.
What you have. Two, dual two-ohm Voice coil subs.
What you want. One, one-ohm load presented to the amp.
What your choices are:
Wire the two voice coils on each sub in parallel. Result, each sub presents a one ohm load. Wire the two (now 1 ohm load) subs now in parallel? 0.5 ohm load to amp. Wire the two (now 1 ohm load) subs now in series? 2.0 ohm load to amp.
Alternatively. Wire the two voice cols on each sub in series. Result, each sub presents a total 4 ohm load. wire the two (now 4 ohm load) subs in parallel? 2 ohm load to amp. Wire the two (now 4 ohm load) subs in series? 8 ohm load to amp.
Neither alternative gives you a 1 ohm mono load to amp.
What you need is two 4 ohm DVC subs. Wire up the voice coils on each sub in parallel which gives you a 2 ohm load on each sub. Wire those two subs in parallel and you'd have a single 1 ohm total load to amp. Or, alternatively, just have two subs made up with single 2 ohm voice coils, wire them in parallel and you have a single 1 ohm load to amp.
Good Luck.
Old Mar 21, 2008 | 02:11 AM
StreetOC192's Avatar
StreetOC192
Good Luck.
What he said......
Old Mar 21, 2008 | 10:33 AM
BEbengali's Avatar
BEbengali
Thanks guys.
I actually don't have the subs yet - which looks like a good thing since I will need 4 ohm DVC subs
I believe this is the way I need to wire it, correct?
Old Mar 21, 2008 | 10:35 AM
StreetOC192
Originally Posted by BEbengali
Thanks guys.
Yes, that diagram will yield a 1 ohm load with 2 - dual 4 ohm voice coil subs.
Old Mar 21, 2008 | 11:11 AM
BEbengali's Avatar
BEbengali
Thank you. You have PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
