Speaker Door Pods
Old Apr 12, 2008 | 08:45 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
thats pretty neat though if you want on axis, DVflyers new set up has it on axis with the oppposite listener
Old Apr 12, 2008 | 12:10 PM
kloudak47's Avatar
kloudak47
Not to hijack the thread but I bought some of Nazar's door pods the 06+ ones and I have had them on for a bout a week (love them btw) but at certain low frequencies the outer edges of the fiberglass pods will vibrate very audibly.
What do you guys (Bing and others who have installed these) use beyond the bolts nazar sends with the pods to get a super tight/flush fit? Should I be using some sort of sealent in addition to a strong/solid bolt pattern?
I called the local car toys here and they said they typically pour more bondo and resin in to the thin parts of the fiberglass and that typically will produce enough strength that the rattle goes away.
What do you guys think?
Thanks
Old Apr 12, 2008 | 12:35 PM
SC350ZR's Avatar
SC350ZR
During all my years with SQ competitions I always aim my speakers, mid and highs, for the dome light just behind your head. That way I have been able to obtain accurate sound stage. Really easy if you use a laser pointer.
You can try to install some Dynamat on the insideof the pods.
That will probably make a difference.
I always use some type of Dynamat on all my fiberglass panels, spray or mat.
Old Apr 12, 2008 | 03:07 PM
jerseystyle's Avatar
jerseystyle
Originally Posted by SC350ZR
This is what I did as a quick way to get the 3-way components a bit more on-axis. Using a Morel 3-way kit.
The speaker grill is cusom made by a friends CNC shop. I have the same design for my subs behind the seats.
This will be redone as I have other plans to redo the complete doorpanel and integrate the pod into the design.
Pretty cool but too much for me. Looks like a space ship or something.
Old Apr 20, 2008 | 04:03 AM
Larold's Avatar
Larold
The ones the OP has are made from a high density foam, no rattle and produce a nice tone.
Old Apr 20, 2008 | 07:56 AM
Peteski's Avatar
Peteski
You might try some weather stipping to the back edge of the pods, thats my plans when I install Nazars Pods.
Old Apr 21, 2008 | 07:38 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Foam? For a baffle?
Old Apr 21, 2008 | 08:18 AM
Larold's Avatar
Larold
Originally Posted by DVFlyer
Foam? For a baffle?
Ya, its a density 6 foam. So, its rigid, but there is no rattle and creates a nice tone. The piece has a wall between 1/2-1" Its also extrememly light.
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
roadmax
Sep 12, 2015 05:55 PM
