How loud are the rear speakers supposed to be?
Old Apr 9, 2008 | 01:31 AM
KJ1225's Avatar
KJ1225
Default How loud are the rear speakers supposed to be?
Hey guys,
I bought my car about a month ago from a fellow member off this forum and they had a system in it already:
some Kenwood Double Din Deck
Alpine Amp
JL 10" Sub
Stock Speakers
as far as I can tell all the stock speakers and the sub are connected to the amplifier.
I removed my sub today because I decided I need more trunkspace over bass and now I noticed little to no sound coming from the rear 2 speakers... I faded the speakers to the rear 2 and it's stilll relatively faint compared to the front speakers.
Is this normal? or is something wrong with the wiring?
Thanks in advance guys!
Old Apr 9, 2008 | 01:39 AM
Sean's Avatar
Sean
are you sure he didn't use left/right rather than front/rear by mistake?
Old Apr 9, 2008 | 01:41 AM
KJ1225's Avatar
KJ1225
Are you talking about the wiring to the amplifier or if I'm using the Balance instead of Fader?
Old Apr 9, 2008 | 01:44 AM
surfcity40's Avatar
surfcity40
Old Apr 9, 2008 | 01:46 AM
surfcity40's Avatar
surfcity40
Old Apr 9, 2008 | 05:16 AM
clarkemtp's Avatar
clarkemtp
If you actually still have the stock "full-range" speakers installed front and rear, what you're seeing is pretty normal in my experience. The stock rear speakers are something like, 32 ohm impedance, if I recall correctly.
A "normal" aftermarket amp is generally rated to deliver it's power to a nominal 4 ohm load. Everytime you double that load, you'll see a 50% reduction (generally) in output power. So, if your amp did, for example...
100 watts/channel @ 4 ohms
Extrapolate that out based on what I just told you and you'll see it's putting out, again only for example:
50 watts/channel @ 8 ohms
25 watts/channel @ 16 ohms
12.5 watts/channel @ 32 ohms
Clearer now why, using the stock rear speakers, you don't have much volume to speak of from the rear channels?
3vilbunny
Jul 18, 2017 05:10 PM
