question on audio setup
Old Apr 10, 2008 | 11:47 AM
kaminariZ's Avatar
kaminariZ
Default question on audio setup
So i have speakers and an amp laying around, and i want to replace the front speakers on the Z. I'm going to be running a JL e4300 amplifier to the front 2 speakers. I have a set of Memphis Msq6.5 components and Alpine spx-177a components. Which set would you say is better? Does anyone know what pods i should get to mount these speakers, and also what ohm and wattage i should run to each speakers? The specs for the amp are below:
Rated Power (stereo):
45W RMS x 4 @ 4 ohm (12.5V);
75W RMS x 4 @ 2 ohm (12.5V)
Rated Power (bridged):
90W RMS x 2 @ 8 ohm (12.5V);
150W RMS x 2 @ 4 ohm (12.5V)
THD at Rated Power:
<0.08% @ 4 ohm (20 Hz - 20 kHz)
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz ヨ 20 kHz noise bandwidth)
Frequency Response:
10 Hz ヨ 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm per ch. / 50 Hz,
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate:
ᄆ 22V/ᄉs
Input Range:
200mV ヨ 8V RMS
Dimensions:
13.8" x 9.25" x 2.36"
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
