SoundStream XXX-10000 10,000 Watt Amp
yup, and you better get some esrious alternators if yo uodnt to kill your electrical system in a heart beat...i say dual 200amp alternators to start with, and run a good 4 setes of 0 guages back...
b
b
LOL @ comments. Thats a insane amount of power bro. 350spl is the man to talk to there lol. If u and 350spl play some bass tracks at the same time even tho yall live far apart u might be able to knock me and blasian's homelink mirrors off. Either that or tear a hole in the space time continum causeing a black hole effect effectively ending the world! Damn black people always trying to end the world!
BTW for those who don't know im not racist just messing with phreaktor
you do not want that amp brother
1st off it uses the same board as the lanzar opti drive 6000 mono
and you would be better off with the lanzar opti drive 6000
the sound stream do not make rated power
and $1600 HELL TO THE NO
tell me what you budget is
what driver you want to push
what electrical budget you have in mind
if you wanna run 4000 watts or better you will need
multiple 1/0 awg runs
a 200 amp alt
the big 3
and at least 3-4 batteries
i can help you to great amps for spl and not spend more than is needed
give me some idea of what you are desiring
a 200 amp alt
the big 3
Originally Posted by 350zspl
i have clamped both 6500 & 10k soundstreams
the 6500 does just over 4000 watts at 14 volts
the 10,000 does just under 6000 watts at 14 volts
and they are current hogs
Design Engineer
a 200 amp alt
the big 3
a 200 amp alt
the big 3
Pics of your setup?
Originally Posted by phreaktor
Also, would the Big 3 make a difference with 2200 watts rms, dual 4 gauge B+, and stock battery/alternator?
you should definetly use 12" or so of 1/0 power wire and re-ground the factory batteries negative terminal to fender use stock location just swap wire , try to neatly sand paint in that area
remove the factory negative ground frame out the area to be sanded with painters tape so as that way you are sanding neatly between the framed out area than replace ground
you can run a new 1/0 lead from alt to positive terminal on battery
it will not hurt only create less resistance
of course if you got and extra $ 250 you can drop a stinger 1000, or kinetic in the factory location
a new 200 amp alt from wrangler is what i use but it aint cheap
it makes 200 amps at 1500 rpm
i run outlaw so i can rev my motor to 1500 and yeild those 200 amps at comps
