Navigation Stopped Working
Old May 1, 2008 | 08:05 AM
nyguy4u's Avatar
nyguy4u
Default Navigation Stopped Working
Hey guys, from one day to the next, my Navi stopped working in my 04' Z. I went to the fuse panel on the drivers side, but only really found a fuse marked "audio" - the rest weren't relevant. That fuse was fine. I also checked the "audio" fuse in the engine bay, and it was fine.
I searched through 23 pages before posting this, so I need some help. Any ideas on what the problem can be?
Thanks.
Old May 1, 2008 | 08:19 AM
RedBullRR's Avatar
RedBullRR
More details would really help. When you say not working, whats not working. The Nav Door, the Nav, the DVD Player.
If its the Nav door, not opening. The Nav will never turn on. This can happen because of a bad Lid Cluster Amp. (Went in my car). You can bypass this, but like I said we need more details.
Old May 1, 2008 | 08:23 AM
nyguy4u's Avatar
nyguy4u
Thanks for the reply.
The Nav door doesn't open. I just went to check the DVD player, and the DVD is spinning in there, so the DVD drive IS working.
Old May 1, 2008 | 12:30 PM
nyguy4u's Avatar
nyguy4u
anyone?
Old May 6, 2008 | 12:26 PM
RedBullRR's Avatar
RedBullRR
Hey What's up,
That's Def your Lid Cluster Amp. You can bypass this but your door will no longer function until you replace the unit. Simply take the center console apart (not hard to do) Rite behind the three gauge pods are two connections. One is for the gauges themselves witch is located right behind the mpg gauge. The other is connected rite behind the Volt Meter Gauge. Disconnect the one behind the Volt Meter Gauge. Your gonna have to manually open your lid, but your nav will now work with out this plugged in.
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Tochigi_236
Sep 27, 2015 03:40 PM
