Change the startup image on DNX7120
Old May 2, 2008 | 10:14 PM
Spork's Avatar
Spork
Default Change the startup image on DNX7120
This may work for the DNX7100 as well.
Here are the instructions for changing the startup image on your headunit.
· First connect the USB Thumbdrive containing image file.
· To enter setup Mode, press SRC+EJECT, then RESET.
· Press and hold FNC & EJECT keys, then press RESET Key.
· Release reset key, and hold FNC & EJECT Key until illumination activates.
· If you want to change the opening image to your own image (i.e., company logo), Press OEM Image.
· If you want to put original KENWOOD opening back,press KENWOOD image.
· Select the image you want to use.
· When the image is loaded, select Enter
Your new opening will remain for few
seconds and then switch to the Source
Select menu.
Old May 2, 2008 | 10:25 PM
cbr900son's Avatar
cbr900son
Cool ill try tommorow on the 7100
Old May 3, 2008 | 08:36 AM
fizmixa's Avatar
fizmixa
please let us know if it works on the 7100. thanks.
Old May 4, 2008 | 01:23 PM
fizmixa's Avatar
fizmixa
Select menu.
was going to give this a try on the 7100, but it does not have a SRC button. i'm guessing we should use the v-sel button (which selects video source).
have a question about this step: To enter setup Mode, press SRC+EJECT, then RESET. do you press SRC and EJECT and then RESET all at once? could you please clarify?
thanks.
Old May 4, 2008 | 01:49 PM
Spork's Avatar
Spork
thanks.
You should have a SRC button...
Old May 4, 2008 | 02:47 PM
twinship's Avatar
twinship
I have the 7100, and what your photo shows as SRC is actually NAV.
FWIW...
Old May 4, 2008 | 03:10 PM
Spork's Avatar
Spork
Perhaps newer/older models?
I'll have to take a look at mine. I think that button is NAV for my 7120 as well.
lapham3
Oct 7, 2022 03:15 PM
