subwoofer mounting
Old May 7, 2008 | 02:21 PM
fizmixa's Avatar
fizmixa
Default subwoofer mounting
was wondering what you recommend to use to get a good "seal" at the subwoofer mounting holes to the box. i've read about the t-nuts, but what other good options are there? right now i'm using weather stripping around the subwoofer hole. i'm not too confident in that. what about some wood glue in the pre-drilled holes for the mounting screws in addition to the weather stripping? any ideas are welcome.
thanks.
Old May 7, 2008 | 02:46 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Weather stripping is fine. Some woofers come with a similar material as a gasket.
I use those black drywall screws. If I could rid the world of T-Nuts I would.
Old May 7, 2008 | 04:14 PM
smaha's Avatar
smaha
+1 on the drywall screws.
Old May 7, 2008 | 04:38 PM
StreetOC192's Avatar
StreetOC192
The drywall scews aren't bad (course thread of course), but I prefer the pan head on these, and they are inexpensive:
http://www.partsexpress.com/pe/showd...number=081-435
Old May 8, 2008 | 02:27 PM
fizmixa's Avatar
fizmixa
so drywall screws huh? i'll give that a go. thanks.
Old May 8, 2008 | 02:58 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Don't be confused by the "drywall" part. They are just course thread screws. Home Depot has them in orange boxes for cheap. The Panhead ones referenced above are good too because they have a bit more surface area but get whichever you see first.
Old May 9, 2008 | 08:53 PM
sosojeffcc's Avatar
sosojeffcc
yeah t-nuts are horrible!
nothin works better than the plain drywall screws with some pilot holes drilled
Old May 14, 2008 | 11:45 AM
fizmixa's Avatar
fizmixa
so i have some air leaks at 2 of the mounting holes after screwing down the subwoofer. is there something you guys recommend to put over the screw and mounting area to give it a good seal? something i can use that is not permanent so that i can replace my subwoofer if needed in the the future?
thanks.
Old May 14, 2008 | 11:53 AM
VO...'s Avatar
VO...
Administrator
thanks.
I believe it depends on what type sub your running and if it's a seal enclosure vs. ported. Regular "drywall" or wood screws are not going to keep that sub anchored very long if your running heavy power. Heavy vibration from a hard hitting sub will cause the screws to back out.
There's nothing wrong with T-nuts or Hurricane nuts as long as you pre-drill the hole properly where the anchor nut sits. Another advantage to a T-nut is that you can remove the bolts multiple times without compromising the wood. MDF is not know for keeping it's shape. If you back out a wood screw too many times, eventually the MDF wood will begin to flake...
Old May 14, 2008 | 11:56 AM
fizmixa's Avatar
fizmixa
its a sealed box, but the screws are anchored fine. its just that i'm feeling small air leaks around 2 of the screws when the sub really starts hitting..
Old May 14, 2008 | 12:05 PM
VO...'s Avatar
VO...
Administrator
Other than torquing down your mounting screws harder, there's nothing I know of since you're already using weather stripping.
However, the Hurricane nuts will allow you put some hellafied torque down if you choose to go that route.
Old May 14, 2008 | 12:35 PM
350zspl's Avatar
350zspl
t -nuts FTW
Old May 14, 2008 | 02:04 PM
DVFlyer's Avatar
DVFlyer
Speed of White
If there is air leaking around the screws and you have any sort of gasket material, something else is wrong. Speaker hole too small- speaker not sitting perfectly flush?
Old May 14, 2008 | 02:06 PM
cbr900son's Avatar
cbr900son
U can use alittle baby powder and sprinkle it on ur sub and push the cone down by hand and see where the air is blowing up the powder to locate a leak btw.
Old May 15, 2008 | 06:28 AM
VO...'s Avatar
VO...
Administrator
+1. I've never had a sub leak when the proper gasket was used and it was mounted flush and tight with all mounting screws/bolts.....
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
