Infinity 6.1 perfect.......do I need door pod?
Originally Posted by KManZ
Spacers needed. Check out zenclosures.com. I had to add some more space still, as the magnets were still hitting my windows when rolled down. I used Dynamat as a spacer.
Originally Posted by sintaxeror
KManZ, you used the 1" Spacers? Do you mind if I add that information to the stock speaker location fitment thread?
But, the spacers alone weren't enough, so to push the speaker further away from the windows, I took the spacer, traced the outline onto some Dynamat, and cut out about 4-5 layers to stack.Some people say to destroy the stock speakers and use the outer mounting rings for a spacer, but I want to be able to go back to stock if I need to sell.
Also, I think the Infinitys come with spacer rings. I only found that out after my install... not sure what size they are though.
bcoffee20
Nov 19, 2015 06:39 PM
