Amp rack in Bose Sub. location
Old Jun 9, 2008 | 05:13 AM
KManZ's Avatar
KManZ
Default Amp rack in Bose Sub. location
My amp is currently in the glove box behind the passenger seat, and I think it is overheating in there, especially these past few days with the near 100 degree temps. Basically, I need to move it somewhere with more space and airflow. My first choice is the vacuous space behind the driver seat; there is more area in there for it to breath in comparison to the glove box. Problem is, I have no clue how to make a rack for it.
Performing a search brings up many examples of people's builds, but no instructions on how to build one. Also, the one guy who was selling pre-fab'd units no longer sells. So can anyone point me in the right direction here on how to build a rack for the Bose sub location, or maybe put me in touch with someone who is selling?
Just a note: I have an understrut sub box; thought about securing the amp to that but for various reasons decided against it. Aside from under the passenger seat, the Bose sub location is really my only choice.
Thanks fellas!
Old Jun 9, 2008 | 05:39 AM
StreetOC192's Avatar
StreetOC192
Making an amp rack isn't too hard nor too expensive. You can get a 1/4 sheet of 3/4" mdf from Home Depot. Then you will need a couple corner braces and a couple metal straps, both of which can be found in the hardware section of Home Depot. Lastly you will need some 1/2" wood screws.
Tools, you will want a tape measure, screw driver or screw gun, jig saw, and maybe some cardboard to make a template of the inside.
Once you have the mdf cut to shape, use the corner braces (you will need to bend them) to mount to existing holes in the front where the bose sub plate mounted. Use the strapping to "hang" the back of the rack from the brackets at the top rear of the sub space. Then you can cover in carpet or paint, or leave raw.
There was a guy on here a while ago who made a few and sold them pretty cheap and he had some pics so you could see what I am talking about, but I can't find that post right now.
Old Jun 9, 2008 | 05:47 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I had a how-to thread but that was back in 2005. I still have the pictures if that helps. Mine was a bit unique in that I stacked two amplifiers one on top of the other. The three straps in the front hit the 10 mm bolts that would have held the subwoofer's mount. In the back you see a slice out of the square for the driver's side rear wheel well and those straps line up with the waiting mounting bracket for a driver's side luggage cubby (for the Japanese right-hand drive market I assume).
Old Jun 9, 2008 | 06:09 AM
StreetOC192
Paul350Z is THE MAN!!!!
Old Jun 9, 2008 | 06:53 AM
gothchick's Avatar
gothchick
Nice install. How's airflow through the speaker grill?
Old Jun 9, 2008 | 07:13 AM
KManZ's Avatar
KManZ
+1 It's gotta be a lot better than in the closed off glove box. I was actually thinking of pulling some old PC fans and mounting them in there w/ the amp, but seeing as there is no new air being moved in, they'd just be pushing hot air around.
Thanks for the pics, though I can't see them at work at the moment Hopefully I can glean enough from the shots to make my own, or at least get me started You have a link to that How-To, Paul?
Old Jun 9, 2008 | 07:14 AM
Mr MoUnTaInMaN's Avatar
Mr MoUnTaInMaN
I am doing the same thing Paul did you cut the sheet metal out "the round hole where the sub was " or does it unbolt I have not gotten that far yet.
P.S. Thanks to All those who have made the awesome diy's for installs really helps
Old Jun 9, 2008 | 07:19 AM
osinrider04's Avatar
osinrider04
kmanz, if you placed the pc fans in front of the speaker grill facing the amps it should draw in the air from outside. I don't know how you'd mount that but it should work.
Old Jun 9, 2008 | 08:13 AM
Iconoclast1's Avatar
Iconoclast1
I dont know if you've seen sintaxeror's build log but hes got a great instructional in there imo.
beginning on the bottom of this post : https://my350z.com/forum/showpost.ph...1&postcount=69
more here : https://my350z.com/forum/showpost.ph...5&postcount=98
even more here : https://my350z.com/forum/showpost.ph...&postcount=104
then he made them look better : https://my350z.com/forum/showpost.ph...&postcount=126
installed and grounded : https://my350z.com/forum/showpost.ph...&postcount=137
Old Jun 9, 2008 | 02:07 PM
KManZ's Avatar
KManZ
Good call, I see what you are saying. I wonder how loud the fans would be.
Paul350Z: nice pics! You know you could make some good dough if you fabbed these up for people on here
Old Jun 9, 2008 | 03:15 PM
sintaxeror's Avatar
sintaxeror
Wow that guy's a badass.
Old Jun 9, 2008 | 03:28 PM
cdoxp800's Avatar
cdoxp800
Here area few shots of mine. I have the Plexy installed. Now I need to paint the amp rack an install the neon light for it.
Attached Thumbnails Amp rack in Bose Sub. location-img_07.jpg   Amp rack in Bose Sub. location-img_06.jpg   Amp rack in Bose Sub. location-img_04.jpg   Amp rack in Bose Sub. location-img_01.jpg
Old Jun 9, 2008 | 03:41 PM
Ghost_shift's Avatar
Ghost_shift
Subbed for info. Thanks for the ideas guys!
Old Jun 9, 2008 | 04:40 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
subd.....looking for ideas for my install
Old Jun 10, 2008 | 01:35 PM
VO...'s Avatar
VO...
Administrator
Old Sep 3, 2008 | 09:28 AM
KManZ's Avatar
KManZ
Re-upping this thread, since I have decided to go active and need to place another amp in the car. cdoxp800, I will be using those pictures to fab up a rack. How did you go about creating it? Anything you recommend doing?
Or, has anyone else decided to jump on the idea of mass producing these for us, and would like to sell me one?
Old Sep 3, 2008 | 06:10 PM
Chi-TownWarrior
I wanted to copy sintax's design......but I cant do chit till after I'm good to walk again
Old Sep 4, 2008 | 07:43 AM
BabyZiLLa's Avatar
BabyZiLLa
How on earth do you guys cable like that in that tight space. Pretty impressive.
Old Sep 4, 2008 | 11:42 AM
adamtaylorpcb's Avatar
adamtaylorpcb
i would but i don't think the market would be there
Old Sep 4, 2008 | 03:05 PM
sintaxeror's Avatar
sintaxeror
agreed... seriously just look at the one I made with a jigsaw and woodglue on the porch of my apartment.. if you are unable to do something similar, then you probably shouldn't be attempting to install a stereo by yourself...
(this is not meant to seem insulting, its meant to emphasize how easy it is to make a similar one).
