Amp rack in Bose Sub. location
Old Sep 12, 2008 | 09:18 AM
  #41
vnarang's Avatar
vnarang
Originally Posted by KManZ
If you go to Home Depot, you can find all sorts of brackets you can use. I got mine in the lumber/roofing section. They are about 6 inches long, and have a series of holes in them. Make sure you buy screws small enough to fit through the holes though. Also, if you are making an amp rack, make sure you get a pack of wood screws that aren't long enough that they pierce through your MDF board.
Oh, and if you take the Z there to buy the MDF board, ask them to cut it in half before you try and fit it onto the car
Couple of questions:
1) Do you have room behind your subwoofer enclosure?
2) Did you have to purchase another 'rear dash' to get the other glove box? If so, where did you get it from?
3) Any idea if I were to get the enclosure for two subs, that there would be room left behind the enclosure too to place things?
4) How is the fit is the enclosure? I only ask because mine was loose and it falls everywhere. Did you need some 'extra reinforcement'?
5) I'd appreciate it if you could post pics soon, as I am judging my next install from this.
Old Sep 12, 2008 | 09:29 AM
  #42
KManZ's Avatar
KManZ
1) Do you have room behind your subwoofer enclosure? - Yes, the enclosure is directly underneath the strut bar only. You have space between the rear speaker ridge and the enclosure
2) Did you have to purchase another 'rear dash' to get the other glove box? If so, where did you get it from? No, I didn't go with another glove box. My rack is just free hanging from the sub mount brackets. I'll try to take some more pics when I get home in a bit
3) Any idea if I were to get the enclosure for two subs, that there would be room left behind the enclosure too to place things? Yes, the same company that makes mine has one for two 10" subs: Zonix Enclosures. They also have ones with amp racks.
4) How is the fit is the enclosure? I only ask because mine was loose and it falls everywhere. Did you need some 'extra reinforcement'? This thing fits VERY snugly, no brackets needed.
5) I'd appreciate it if you could post pics soon, as I am judging my next install from this. Pics will be provided before sundown
Replied.
Old Sep 12, 2008 | 09:38 AM
  #43
vnarang's Avatar
vnarang
Replied.
Thanks!
Another thing, do you think you could also take pictures of your amp location, facing it, from the outside? Also, what are you doing about the 'heat'?
Sorry for so many questions.
Old Sep 12, 2008 | 10:29 AM
  #44
KManZ's Avatar
KManZ
Pics of sub enclosure in the car are attached.
Thanks!
In this picture, you are looking at the cubby behind the driver seat. If you pop your driver seat forward and look behind it, thats what mine looks like too. Everything looks stock until you pop off the blank cover.
My amp is grounded to a bolt in the floor of the hatch between the sub and rear speaker deck, on the opposite side from the child safety latch, under the carpet. The sub wires also run under the carpet.
Attached Thumbnails Amp rack in Bose Sub. location-amprack-002.jpg   Amp rack in Bose Sub. location-amprack-003.jpg   Amp rack in Bose Sub. location-amprack-004.jpg
Old Sep 12, 2008 | 11:26 AM
  #45
vnarang's Avatar
vnarang
Ahh, I understand. I thought you had some type of cover on there. So it's just open, correct?
Old Sep 12, 2008 | 12:27 PM
  #46
KManZ's Avatar
KManZ
Right, the blank panel is just popped off so I could take pics. If you have a non-Bose system, just flip your front seat forward and you will see the cover to the cubby. Just use it again after you put the rack in there.
Here is what it looks like when you are working on the amp rack. You have to take the plastic off around the cubby, and from there the Bose sub bracket (not pictured in this pic).
https://my350z.com/forum/attachments...-opened-up.jpg
As for the heat, the amp is really efficient, so doesn't really generate too much heat. It is better off where it is now rather than in the glovebox, as there was hardly any air moving in there.
Old Sep 12, 2008 | 12:48 PM
  #47
Jes-Z's Avatar
Jes-Z
If you remove the plastic panel you might find a metal subwoofer mount. It's 6 bolts to remove and then you'll have access to the open space.
Old Sep 12, 2008 | 02:04 PM
  #48
vnarang's Avatar
vnarang
Yeah it's there. How do you get a glass or plastic 'window' in the back panel? Is it custom?
Old Sep 12, 2008 | 02:26 PM
  #49
KManZ's Avatar
KManZ
Yeah, custom work for sure.
Old Sep 21, 2008 | 12:57 PM
  #50
ColoradoClark's Avatar
ColoradoClark
Here ya go. No measurements for the bolt points, but those are easy to measure out. I crudely drew them on to the pic for you though. You'll figure it out
And here ya go.
Kman: you ROCK! Sorry I didn't respond sooner: I just started tearing into the vacant driver-side space today, after spending the last couple of weeks buying most of my new sound system (and learning a lot about car audio along the way!).
Your amp shelf specs are going to be priceless -- I should be able to get the shelf done today with the info.
Thanks, again!
Sean
Old Sep 21, 2008 | 08:50 PM
  #51
quakerroatmeal's Avatar
quakerroatmeal
Got my amp rack done today, I'll take pics of it soon. And to take the sub bracket off I believe it's like 14 bolts, and a pretty pita imo, they made dang sure that thing wasn't gonna move.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
