car alarm goes off randomly
Old Jul 9, 2008 | 11:44 PM
three's Avatar
three
Default car alarm goes off randomly
anyone know why my car alarm goes off randomly? it usually only does this when parked outside.
Old Jul 10, 2008 | 12:23 AM
SiNzz's Avatar
SiNzz
Peoplez is stealingz ur carzzzz.
Seriously though, maybe a faulty shock sensor? Is this a stock alarm or aftermarket?
Old Jul 10, 2008 | 12:10 PM
three's Avatar
three
it's aftermarket, viper, forgot the model number. thanks!
Old Jul 10, 2008 | 01:31 PM
350ztoronto's Avatar
350ztoronto
i got the same probelm, im worried that someone will kick my car cause its pisisn them off =(
Old Jul 10, 2008 | 02:16 PM
three's Avatar
three
the alarm only goes off at night around 12am-3am also and it is right outside of my apartment. i can literally look out my window and see it and no cars have drove by or there is no one on the street. weird! must be a faulty sensor but so random!
Old Jul 16, 2008 | 09:35 AM
KPierson's Avatar
KPierson
Did the system use your OEM hood pin?
The OEM hood pins have a tendency to false alarm (especially if you have an aftermarket hood).
I would start there, pop your hood and locate the little plunger looking thing that the hood contacts when it closes and disconnect the wires from it for a few days. If your false alarms stop reposition the plunger to make better contact or replace the switch.
If you still have false alarms use the alarms built in status display to figure out exactly which zone is triggering. You should be able to count the LED flashes once you disarm the system and the number of flashes will correspond to a zone. Look in the book and the book will tell you what zone that is. Once you know the zone you can then figure out how to fix it.
Old Sep 13, 2008 | 02:28 AM
three's Avatar
three
thanks! the sensor is the shock sensor, when the alarm goes off. still goes off randomly early in the AM, seems to be a temperature thing????? when is starts to get into the 50s or cooler, the alarm will usually go off randomly. i used to park in my garage and never had this problem. could it be a temperature thing?? thanks!
etkms
Jun 19, 2022 06:30 PM
kyin
Sep 29, 2015 06:57 AM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
AbyteZero
Sep 22, 2015 09:17 AM
