quick wiring help please
ok, im getting the wiring harness all soldered up but there are a few that dont match up
i have a metra kit going to a alpine iva x100 harness
on the metra side i have 1) amp turn on 2) amp ground 3) dimmer
on the alpine side i have 1) audio interupt in 2) remote turn-on
if im using an amp to run my mids and highs i dont need to connect the wires right?
let me rephrase:
i am running my mids and highs off of an amp. do i need to connect each posotive and negative for each channel coming from the head unit even if i wont be using them?
no you don't connect them. cap off the three you listed on the metra side. then the audio interupt would be used if you have a telephone system installed. the remote turn-on would be run to your aftermarket amp.
Sorry to jump in, but I figured your questioned were answered..
The audio interrupt - would you need this when you use the KCE bluetooth unit? Doesn't the unit plug straight into the headunit? Or do you splice it up with the interrupt wire?
350Z_Al
Oct 29, 2020 07:44 PM
