Sub/Amp Help
Old Jul 23, 2008 | 08:16 PM
JonnyRod's Avatar
JonnyRod
Default Sub/Amp Help
I'm trying to find a decent quality single 12" sub and amp combo for under $500. I'm doing a nice little build in my girlfriend's civic, and the only brand ive ever dealt with is Memphis. But I'm lookin for something a little 'prettier' this time for her though, like audiobahn, beacause the sub will be inverted. Currently i'm leaning towards these...
http://www.woofersetc.com/index.cfm?...roduct_ID=4158
http://www.woofersetc.com/index.cfm?...roduct_ID=4155
Willthis combo work well? Quality sound? Any other product suggestions would be great...and by the way that woofersetc.com is a great site
Old Jul 23, 2008 | 09:15 PM
Roper215's Avatar
Roper215
Default Amp / Sub
Depends on the type of music you want to listen to...
Hifonics makes good stuff, I am a fan of Zapco now. Image Dynamics has some high quality subs as does Fi... not sure what you define as pretty... but I'd much rather have high quality functioning equipment...
I am in the process of installing a Zapco 200.2 and a 500.1. Focal fronts and an Image Dynamic IDQ10. The stuff is pricey but woofersetc sells all of the brands but Fi and you can purchase them directly anyway.
It's really just based on your listening preferences though, plus go to a local shop and check out some different sub/amp combos and pick out something you like. What I like and how I tune my system you may find to be horrible...
Old Jul 24, 2008 | 04:15 AM
StreetOC192's Avatar
StreetOC192
PLEASE PLEASE PLEASE run away from the Audiobahn garbage!!!!!!
Diamond Audio D612d2 (IMHO a beautiful aluminum cone and a gorgeous magnet/motor structure):
http://www.woofersetc.com/index.cfm?...roduct_ID=2703
Crossfire XP600D:
http://www.woofersetc.com/index.cfm?...roduct_ID=5815
This will give you a fantastic setup for $520. Bridge the sub down to 1ohm, and you will be getting a very conservatively rated 600 rms to the single 12" sub. The Diamond D6 line is their more SQ oriented sub, so it will give you very nice sub bass, but is not an overly obnoxiously loud sub. I like these drivers sealed, but ported could be done well too.
Old Jul 24, 2008 | 06:11 AM
JonnyRod's Avatar
JonnyRod
Crossfire XP600D:
OK see this is the stuff i'm looking for thank you. any more suggestions?
Old Jul 24, 2008 | 01:03 PM
JonnyRod's Avatar
JonnyRod
c'mon someones gotta be able to suggest another combo...
Old Jul 24, 2008 | 03:01 PM
StreetOC192
Same amp, but go with an AudioPulse Epic 10"
http://www.funkywaves.net/catalog.cfm?item=epic_10
Old Jul 24, 2008 | 04:48 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Fi Q12 $259
https://ssl.perfora.net/www.ficaraud...iew.shopscript
hifonics $195 - http://www.sonicelectronix.com/item_...08D.html#specs
that put you at $454
Old Jul 24, 2008 | 05:10 PM
JonnyRod's Avatar
JonnyRod
Originally Posted by Chi-TownWarrior
this sounds really good...been readin about that Q12...the thing looks pretty impressive!
Old Jul 24, 2008 | 05:15 PM
JonnyRod's Avatar
JonnyRod
where would be the best place to buy the Q12? and what is the BP Power? worth the extra $40?
Old Jul 24, 2008 | 05:25 PM
Chi-TownWarrior
direct from their site
BP power......
We just added the "BP Power" option to both the SSD and Q series subwoofers.
This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack.
All of these new features increase power handling from 200-500 Watts depending on the application.
Old Jul 24, 2008 | 08:51 PM
JonnyRod's Avatar
JonnyRod
I've got a Memphis 16-MC1500D:
MClass Series
1 x 750W @ 4 ohms (0.75% THD)
1 x 1500W @ 2 ohms (1% THD)
S/N Ratio: >100dB
Freq. Response: 10Hz ∼ 650Hz (± 1dB)
Same board as Memphis 16-ST1500D
Will this work well with the Q12? Or would the hifonics amp be a better choice for this sub?
Old Jul 24, 2008 | 10:23 PM
-AR-'s Avatar
-AR-
Try this link http://www.edesignaudio.com/, good quality and prices, and great customer service.
Old Jul 25, 2008 | 03:57 AM
StreetOC192
IMHO I wouldn't power a great sub like the Fi Q with a marginally mediocre amp.
Old Jul 25, 2008 | 05:41 AM
Chi-TownWarrior
That was one of the amps you actually suggested to someone else with a similar setup, plus at the Fi forum that was a recommended amp as well
Old Jul 25, 2008 | 05:42 AM
Chi-TownWarrior
MClass Series
S/N Ratio: >100dB
if tuned correctly
Old Jul 25, 2008 | 06:03 AM
StreetOC192
I actually do believe you are correct. Was it to pair with a Fi Q? I can't remember. The reason behind my comment above is the Fi Q is a SQ oriented sub whereas the HiFonics TXi amps are not really SQ oriented amps. For the money, the HiFonics amps are hard to beat, but if the budget allows, I would look a little higher up the SQ chain.
Old Jul 25, 2008 | 06:17 AM
StreetOC192
But then thinking to myself, I'm being kind of hypocritical here I guess because I usually maintain the stance that "a watt is a watt", at least with subs. And I do still stand by that. For sub duties, I usually always say that the coloration from an amp is not noticed. So my thought process when typing the post above #13 would really apply more if the amp were to be paired with a nice set of comps rather than a sub. I concede that although there is a difference with subs that are designed for SQ, I do not believe there is much of a discernible difference in class D monoblocks that would classify one "more SQ" than another. The sheer topological inherent characteristics defies that logic.
Old Jul 25, 2008 | 06:19 AM
350zspl's Avatar
350zspl
hifonics titan entry level
hifonics zeus next step up
hifonics brutus another step up
hifonics XXV top notch SQ and spl
Old Jul 25, 2008 | 04:32 PM
JonnyRod's Avatar
JonnyRod
basically i'm sold on the Q12...i need to know what amp would be the BEST choice for this sub in a ported 2.5 cubic foot enclosure.
i also need a 4 channel amp for my mb quart RCE216 6.5's...
parrotheadmatt
Feb 20, 2013 06:01 PM
joem1cha3l
Oct 28, 2010 02:55 PM
tonysZ
Jun 9, 2005 07:10 AM
dan-14
Apr 10, 2005 08:14 PM
