DNX 8120 IPOD compatibility
Old Jul 25, 2008 | 03:21 AM
beau87's Avatar
beau87
Default DNX 8120 IPOD compatibility
I need someone with more knowledge of IPODs than I have to help answer a question. I have installed a DNX-8120 and previously ran a 5th generation IPOD off the DNX-8120 head unit and it everything worked perfectly. Now I went out and bought a brand new IPOD classic 80 GB version and it will not interface with the head unit at all. The IPOD is playing and I can hear music when I select the function on the head unit, but the unit never recognizes the IPOD. Does anyone have any information that might clear this up for me?
********Long story short, 3' extension cable prevents IPOD signal from syncing up with DNX-8120. I removed extension cable and now have only KCA-iP300V in-line with DNX-8120 cables and IPOD classic works. Crutchfield gets a thumbs up for their tech support. Kenwood gets a big fat 0. I wanted to make sure the correct information is disseminated in this forum. Sorry if I confused anyone.********
Old Jul 25, 2008 | 03:45 AM
cyberkline's Avatar
cyberkline
Do you have the newest update on your HU?
Old Jul 25, 2008 | 04:26 AM
beau87's Avatar
beau87
When I bought the head unit it had a big sticker on the outside of the box that stated that the unit had been updated. I went to the Kenwood support page for IPOD compatibility and didn't see any updates available for the DNX-8120. I am not really sure where I would find version number for the IPOD software installed in the DNX-8120 head unit.
Old Jul 25, 2008 | 05:52 AM
Chi-TownWarrior's Avatar
Chi-TownWarrior
try doing a hard restart of your iPod
http://support.apple.com/kb/HT1320.
If that doesn't work make sure that your iPod is connected to the correct USB cable (the one with the iPod label on it), check to see if you have a proper ground for the HU. let me know if that doesn't work (former OWC/apple sales)
Old Jul 25, 2008 | 06:40 AM
beau87's Avatar
beau87
Like I stated above, I had a 5th generation IPOD connected to the HU and it worked great. I never disconnected the adapter cable, so I don't see how it could be connected to the wrong USB, but I tried both when it didn't recognize the IPOD anyway. Ditto on the ground for the unit. I did read in another forum that this generation IPOD included encryption in the cable included with the IPOD, is this true? I was going to home tonight and try to connect the IPOD to the HU with the cable included and see what that does. IPOD software version is 1.1.2 PC
Old Jul 25, 2008 | 12:26 PM
Chi-TownWarrior
there is no encryption or anything like that. I also have a iPod classic (160), and the same HU. I can connect my iPod to any HU, radio with a dock, xbox, etc without problems. Make sure you are up to date with your iPod software, if anything try doing an iPod restore. Let me know how that goes.
Old Jul 25, 2008 | 02:03 PM
beau87's Avatar
beau87
First I want to thank you for your help, it’s much appreciated. I borrowed a friends’ 5th generation IPOD and it didn’t work either. In a gamble I plugged in the cord that came with my IPOD to the USB connection on the HU and low and behold the deck immediately recognized the IPOD classic. I believe now that I have a bad KCA-IP300V cable and have called the company to replace it. Hopefully this will fix the problem.
Old Jul 29, 2008 | 05:31 PM
beau87's Avatar
beau87
Well the latest update is not encouraging to any new IPOD owners. I called Kenwood support this afternoon after the new Kenwood KCA-iP300V cable that I received as a replacement for the original did not work with my IPOD classic. Kenwood has informed me that in fact Apple has added a verification routine in to the “NEW” IPODS’ that is causing Kenwood cables not to work with these IPODS. Kenwood has also informed me they have received an ever-increasing number of complaints and presently have no work around for these changes. So as of right now I am out of luck.
Old Jul 29, 2008 | 05:36 PM
Chi-TownWarrior
I find that very odd. I will get with my friends that still work there and see this. As I said before I have an iPod classic 160gb and have no problems.
Old Jul 29, 2008 | 05:42 PM
beau87's Avatar
beau87
Kenwood said it is only effecting the latest IPODS. Explain this, my original apple USB cable works fine with the deck, just no sound or video of course, two Kenwood cables can't interface with deck, but output sound, no video. I am going to guess the IPOD classic you know works was manufactured earlier the hardware cycle, mine is brand new. Better yet call Kenwood yourself and while your at it post a complaint to Apple. If Microsoft did this it would hammered to no end.
Old Jul 30, 2008 | 08:40 PM
extra300's Avatar
extra300
I have a DNX-7120 basically the same as 8120. I'm using a iPod Touch (with latest 2.0 software) via Kenwood KCA-iP300V cable. With the 2.0 update I can NOW play VIDEO. The previous Ipod Touch software gave me AUDIO only. Whatever Apple did in there current update made an improvement with the Kenwood unit.
Not sure why Kenwood said there having problems with the 'New' Ipods. The Ipod Touch is fairly new and the Kenwood cable works just fine.
I don't believe its a Kenwood issue, more like Apple or maybe both?
Old Aug 6, 2008 | 03:12 PM
beau87's Avatar
beau87
updated information in post
Old Dec 14, 2008 | 12:27 PM
LeMansZCa's Avatar
LeMansZCa
Are you guys still having problem with the new ipod?
I have recently purchased the 8120 and was able to hook up my iphone to it. it can play the playlist and shows the music video.
Although, when i connect the iphone to the cable(Kenwood KCA-iP300V), the iphone shows a message that the connector is incompatible and the phone does get a lil warm after connecting to it.
I have ordered the new 16G Nano and was wondering if you guys have experience with it now that it's one year later!
thanks!
Old Jan 12, 2009 | 05:15 PM
Goku350z2007's Avatar
Goku350z2007
do you have the new iphone or the old iphone? the reason i asked is because im doing the same setup and i have the old iphone
Old Jan 12, 2009 | 09:32 PM
LeMansZCa's Avatar
LeMansZCa
I have the new phone. Prob better to use a Nano for the music. I still have prob with the speaker that came with the 8120. No one can really understand what i am saying but i can hear them fine when using the BT
Old Jan 13, 2009 | 05:37 AM
Goku350z2007
sounds dont come out of the speakers while using the iphone, but you can hear the music when using your blue tooth headset? is that you are saying?
Old Jan 13, 2009 | 12:35 PM
LeMansZCa's Avatar
LeMansZCa
sorry for the confusion...
I can hear the music from the speakers. I can also hear incoming calls thru the speakers. But when i am talking using the 8120 mic, the receiving party has a hard time hearing me clearly...
Old Jan 13, 2009 | 06:16 PM
Goku350z2007
maybe the mic that comes with the 8120 is not close enough to you, try using a bluetooth mic see if that works
Old Jan 13, 2009 | 10:44 PM
LeMansZCa's Avatar
LeMansZCa
u mean to see if the 8120 can connect with my JawBone II?? maybe i can give it a try... i don't think the 8120 is that smart...ha!
Old Jan 14, 2009 | 08:39 AM
Goku350z2007
no not the Jawbone try to find someone that has a bluetooth mic see if that works, or it could be the connection to the Head unit is not connected all the way in
