Newbie needs help from experts!
Old Aug 4, 2008 | 11:58 PM
Ernie350z's Avatar
Ernie350z
Default Newbie needs help from experts!
Hey guys! i just ordered my ipod interface for my eclipse avn6610 (ipc106). I was wondering if i can get any help/hints/links how to install it? and yes, i tried days and days to search from this site or at googles. any little help i appreciate!!
Old Aug 5, 2008 | 01:43 AM
StreetOC192's Avatar
StreetOC192
Not sure what you mean how to install it. Did you install your AVN unit?
My iPC106 is installed under the center stack next to the manual shifter on the transmission tunnel. I used some velcro to keep it from rattling around. For wiring, it's one plug that goes to the back of the AVN headunit and then the power and ground wires that you can tap into the power and ground going to your AVN.
Old Aug 5, 2008 | 04:51 AM
rotaryrocket7's Avatar
rotaryrocket7
Here's a tip/issue that I ran into.
When installing, make sure you set the two selector switches to the correct position ( the a/b switches) before connecting the power harness. Once the unit has power you cannot move the switches and change the setup without disconnecting the power first.
Otherwise it's really straightforward as mentioned above.
Old Aug 5, 2008 | 07:08 AM
Ernie350z's Avatar
Ernie350z
yea, my headunit its already installed. but the only part that i dont understand its where to put the power wire?? i know the owner's manual says to the battery12? do i have to wire straight the battery?
Old Aug 5, 2008 | 07:09 AM
Ernie350z's Avatar
Ernie350z
i think my should be B/B? cuz i have the 2006 H/U? maybe i wrong lol i dunno
Old Aug 5, 2008 | 07:13 AM
StreetOC192
If i'm not mistaken, it needs to be hooked to the +12v, which would be the yellow wire that is behind your headunit. The 'switched' power I believe is bundled in the barrel connector that hooks to the rear of the headunit. I'm pretty sure that is how mine is hooked up. It's been 2 years since I installed mine.
Old Aug 5, 2008 | 07:58 AM
Ernie350z's Avatar
Ernie350z
thanks streetoc!!! now imma try to install either today or tomorow...so u saying i dont need to do anything crazy like disconnecting the battery or something like? just hook up the yellow power wire to the 12v yellow wire behind the unit?
Old Aug 5, 2008 | 08:21 AM
StreetOC192
Whenever working on electrical elements in a car, it's always a good idea to disconnect the negative battery terminal.
Old Aug 5, 2008 | 08:22 AM
rotaryrocket7
He's right about the wire behind the unit. Whichever has a fuse on it is the 12v constant source, i think it was yellow...
You do need to disconnect the battery when installing this, leaving it on could cause issues if you ground something out during the install. Better safe than sorry...
m_0g
Jun 3, 2021 10:05 AM
carid
Misc.
Sep 10, 2015 06:16 AM
ricks350z
Dec 5, 2012 03:51 PM
lauderdale75
Jan 9, 2003 06:23 PM
