Need Stock (Non Bose) Speaker Pinouts Please!
Old Jul 29, 2003 | 04:07 PM
Zaph32's Avatar
Zaph32
Exclamation Need Stock (Non Bose) Speaker Pinouts Please!
I've asked this in the context of other threads a couple of times and didn't get an answer...so I'll ask it directly!
I need to tap the speaker leads (all four of them) for the basslink. This will probably happen behind the dash since I can readily get all four that way.
Can someone please provide pictures and/or pinouts for the factory radio/harness?
1. Don't tell me to get a head unit, I don't want one right now and will add one later if I feel the need.
2. Don't tell me to get an amp. See #1.
My plan for right now is to change the speakers and add a basslink - that's it.
Thanks for the help!
Old Jul 30, 2003 | 12:12 AM
alphared's Avatar
alphared
well having to spare you the burden of a search
here goes.
on the block with 10 pins (big one in the middle)
Looking at the Wire Harness Face on:
________________
02 04 ==== 08 10
01 03 05 06 07 09
Front speaker are:
Left speakers Postive (02), Ground (01)
Right speakers Postive (04), Ground (03)
Those branch off to speakers and tweaters
Incase you get flipped on the diagram:
Pin 06 (big yellow one) is Battery power
Pin 05 is ACC power
The rears are the 8 pin to the left of that one
___________
12 ==== 16
11 13 14 15
Left speakers Postive (14), Ground (13)
Right Speakers Postive (16), Ground (15)
I know you asked for pinout for the HU, just mirror the diagrams above for that, figure you were going to tap into the wireharness anyway.
Old Jul 30, 2003 | 05:30 AM
Zaph32's Avatar
Zaph32
I did try to do a search, but I guess I didn't try hard enough.
At any rate, that was exactly what I needed, many thanks! You correctly guessed that I'll be tapping the harness.
I really appreciate it!
Old Jul 30, 2003 | 05:34 AM
Zaph32's Avatar
Zaph32
Originally posted by alphared
Front speaker are:
Do they go through a crossover? My plan was to replace the stock midbass with a full range speaker, and just disable the stock tweeters. If the "branch" is just a plain split (wired in parallell) I have no problem, but if they are going through some kind of crossover before getting to the doors, I'll have to wire my own stuff.
Old Jul 30, 2003 | 02:25 PM
chicago350z's Avatar
chicago350z
the previous post is a little confusing to me. here is my version:
LF:
White+
Blk-
RF:
Grn+
Red-
LR:
Brown+
Blk/Red-
RR:
Pink-
Blue+
Looking at the previous diagram, I believe all my colors matched up. Good luck!
Old Jul 30, 2003 | 03:10 PM
Zaph32's Avatar
Zaph32
Thanks for the extra info!
Any thoughts on my crossover question?
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
