help me how to wire my subwoofer
i have 2 kicker solobaric l7 10 inch subs with rockford fosgate p6002. my subs are 4ohm DVC. i was wondering if i could wire them as 1 ohm like mono. i know that my amp are not supposed to be wired as 1 ohm, they recommend setup as 4ohm max. my subs are 600rms and peak is 1200 each.and my amp is peak 2100 or so. can i wired them as 1 ohm mono subwoofer?
Originally Posted by mustangdt67
really? i thought if you have 2 DVC 4ohm subs, u can wire 1 ohm.
I would have sworn it was halved in parrellel, doubled in series. So two 4s would be a 2 or 8 ohm load depending on your choice.
However, your amp will tell you how low you can go, if the impedence goes to low it may give you a light, a low imp light....see if you have one.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
Beater350z
Sep 9, 2015 03:36 PM
