NEW AUDIO INSTALL AVIC-F700BT ... pics
Old Feb 10, 2009 | 04:58 PM
  #41
KYEXTAZ's Avatar
KYEXTAZ
did you have the bose speakers? when i looked into replacing my bose headunit they told me I would need to rewire all of the speakers and amp as well.
Old Feb 11, 2009 | 08:09 AM
  #42
BenchTT's Avatar
BenchTT
Should just plug into harness to utilize bose amp/speakers. If I am wrong I need to know ASAP because I will be doing this install within a month with the f90bt using stock blose amp/speakers.
Old Feb 27, 2009 | 08:01 PM
  #43
muenster84's Avatar
muenster84
that looks really good i just got the same one like 2 days ago i installed it but i have one problem i go to settings and i cant go to system settings or navi settings would that be becuase i didnt hook up the green wire to the ebrake and my car is not in motion....... if some one can please help me or give me a link to how to install it thanks
Old Feb 28, 2009 | 07:03 AM
  #44
dudegetalife's Avatar
dudegetalife
ya i just got this unit best buy charging 100+50 for parts for install and cartoys doing 175 flat dahm does anyone know a better deal or a nice how to guide?
Old Feb 28, 2009 | 08:17 AM
  #45
adamtaylorpcb's Avatar
adamtaylorpcb
if you cant figure out how to wire a head unit i wouldnt advise taking your car apart
Old Feb 28, 2009 | 09:32 PM
  #46
guitman32's Avatar
guitman32
Can I ask you how you got the Metra kit to fit that well?
I'm installing my f900bt and it seems askew in the double din bezel. To specify, there is a sizable gap between the bottom of the unit and the top of the lower bezel.
Maybe I mounted it wrong?
Old Mar 1, 2009 | 08:18 AM
  #47
Peak350's Avatar
Peak350
There was a small gap on mine out of the car, and I was concerned, but in the car because there isn't light behind the head unit, it didn't look out of place. Just try to get the gap to be even all the way around.
Old Mar 1, 2009 | 08:24 AM
  #48
haeshik's Avatar
haeshik
My friend got his installed at Best Buy and he has to stop inorder to use his navi, etc... i got mine installed by a homie who has his own shop and he did a bypass for me that way i can use navi, etc... while im driving
Old Mar 1, 2009 | 10:04 AM
  #49
Peak350's Avatar
Peak350
The bypass is pretty simple, but more complicated than most. The F series units use the GPS to tell if you are moving, as well as the E-brake ground wire. If you ground the e-brake wire, and move the un-used mute wire (pin and all) to the correct pin spot on the harness, you end up with a unit that lets you in settings at all times.
Old Mar 1, 2009 | 02:51 PM
  #50
guitman32's Avatar
guitman32
Thanks. I finished my install this morning and the result was exactly as you described...the gap is not very visible because there is no backlight shining through.
However, I did notice from some angles a slight gap between the bottom of the Metra kit and the dash. Nothing too serious though...will be filled easily.
Once again, nice install!
Old Mar 2, 2009 | 03:19 PM
  #51
muenster84's Avatar
muenster84
do you no how your buddy bypassed it if so please let me no i really want to get this installed
Old Mar 2, 2009 | 03:31 PM
  #52
Peak350's Avatar
Peak350
Hardware bypass.
Old Mar 2, 2009 | 03:46 PM
  #53
dudegetalife
Hardware bypass.
so you move the 4th one 2nd row to where exactly?
Old Mar 2, 2009 | 04:12 PM
  #54
Peak350's Avatar
Peak350
Ok, basically, on the harness there is a mute wire that no one uses (that I found at least). You can pull that wire from the harness, its located in the pin labelled "1" in that chart. You put it in the spot labelled "2" and ground the other end (along with the green "parking brake" wire).
The picture at the top is how the harness plug will look when done, bottom is how it looks BEFORE the bypass.
Old Mar 2, 2009 | 08:52 PM
  #55
theKoosh's Avatar
theKoosh
yeah bump to answer this question too haha.
to the OP and everyone else who has a 700BT: has anyone tried using A2DP?
Old Mar 3, 2009 | 11:34 AM
  #56
350Zum's Avatar
350Zum
I am installing a AVIC F900bt 2.0 next weekend - is there anything I should know about mounting? Does the Metra kit fit the best? Im also installing 2 JL amps and front JL 6.5s do they fit rite in or do they need a spacer?
Old Mar 3, 2009 | 02:01 PM
  #57
dudegetalife
besides a wiring harness is their anything else needed to install the avic-f700bt?
Old Mar 3, 2009 | 03:22 PM
  #58
Peak350's Avatar
Peak350
Wiring harness adapter and dash kit.
I recommend that you run your wires somewhere that you can get to them easier (buy RCA cables and such if you ever plan to run amps, etc.) and not have to pull the head unit again. Its hard enough to get out and back in that its worth it have the ease of upgrade later.
Old Mar 5, 2009 | 09:12 PM
  #59
siruis's Avatar
siruis
Ok so i plan on buying the Pioneer AVHP4000DVD. I am also getting the sirius Pioneer CD-SB10 and SIRIUS SCC1 SIRIUS for satellite radio. The steering wheel controls, the ipod cable. A fellow user will sell me a wire harness and dash kit. Is there anything else i need to install this with sat radio. I plan on doing the bypass as well!
Old Mar 15, 2009 | 10:50 AM
  #60
matix101vz's Avatar
matix101vz
everyone who asked what else they needed for the install ... i updated the info in the thread take a look
