NEW AUDIO INSTALL AVIC-F700BT ... pics
Old Sep 17, 2008 | 04:56 AM
matix101vz's Avatar
matix101vz
Default NEW AUDIO INSTALL AVIC-F700BT ... pics
I just recently upgraded to the Pioneer AVIC-F700BT and i love it. I never installed a radio in a car before and i wanted to try it with this one. I looked up all the install guides on here and the wiki and thought it was going to be a breeze, well without those i wouldnt of been able to do it, so thanks. The unit looks OEM with my blue conversion bc all of the lights in the whole car now match perfectly.
So anyway i got to work, i got a little nervous when i had to drill holes for the mount but it came out flawless, then i had to run a wire all the way to the rear reverse light and had to drill a hole thru the trunk to sneak the wire (that was a little nerve wrecking). The hardest part of it all was trying to stuff all the wires in. (its alot easier with an extra hand, esp when your trying to screw in the 2 ground wires).
After it was all done i had my brother turn to key to see if it worked and it did!!, i was extremely happy i didnt mess anything up. GPS worked perfect, bluetooth was great, and ipod is nice.
By the way i custom ran the ipod wire and cut out a hole in the console in the armrest so i never have to take my ipod out and you dont see 1 wire.
im in the process of taking all that nasty felt out of the center console, so there will be pics of it soon.
(does anyone know a good place to get cloth and a good spray adhesive to refinish the console)
OK this is for everyone asking what other things you will need with this install.
depending on the year of your car 03-05 or 06-08 you will need 2 things.
For 03-05:
1. Metra dash kit
http://cgi.ebay.com/Metra-99-7402-Ni...2em118Q2el1247
http://www.amazon.com/Metra-99-7402-.../dp/B0006Z9K28
2. Wiring harness
http://cgi.ebay.com/ebaymotors/Radio...spagenameZWD1V
For 06-08:
1. Metra dask kit
http://www.audio-discounters.com/99-7602.html
2. Wiring harness
http://cgi.ebay.com/06-NISSAN-350Z-C...2em118Q2el1247
FOR ALL
Ipod wire
http://www.amazon.com/Pioneer-CD-IU2...7142979&sr=8-1
Here are the pics (i also just got the Evo-R Titanium shift ****)
Old Sep 17, 2008 | 05:04 AM
UofA350Z's Avatar
UofA350Z
Nice!
Old Sep 17, 2008 | 06:53 AM
Concave's Avatar
Concave
looks nice! I was thinking about it but does yours take 2 minutes to boot up too?
Old Sep 17, 2008 | 07:46 AM
1_SIK_Z's Avatar
1_SIK_Z
Nice work!!
Old Sep 17, 2008 | 07:50 AM
SFMACGUY's Avatar
SFMACGUY
Dl the new firmware for it, it will make it boot faster, and help the BT. Also its a lot easier if you bypass it prior to installing (moving mute wire to an additional plug) so you only have to ground the reverse, and mute, instead of runnign it back.
Old Sep 17, 2008 | 08:06 AM
IronYuppie's Avatar
IronYuppie
its a great gui huh? i have the avicd3 but was mulling getting this, hope it turns out good for you
Old Sep 17, 2008 | 09:05 AM
quakerroatmeal's Avatar
quakerroatmeal
Looks pretty good, but one thing that really popped out for me, WTF is wrong with your armrest console? Looks like there's mold and looks pretty dang disgusting, you should clean it out once in a while...
Old Sep 17, 2008 | 10:19 AM
ev0k1ll3r's Avatar
ev0k1ll3r
^^^ +1 that **** looks gross! clean that for sure
Old Sep 17, 2008 | 10:26 AM
matix101vz's Avatar
matix101vz
its like old felt or something i dunno what i can do with it
Old Sep 17, 2008 | 10:27 AM
Fusionrace's Avatar
Fusionrace
Very nice.
How much did you get the unit for?
Old Sep 17, 2008 | 10:28 AM
matix101vz's Avatar
matix101vz
total was 577 for unit, harness and trim
Old Sep 17, 2008 | 10:34 AM
quakerroatmeal
Try some products, and scrub it out, steam vac, and dry it? Or see if you can take the actual felt off and replace it maybe.
Old Sep 17, 2008 | 11:53 AM
matix101vz's Avatar
matix101vz
would an 06+ center console fit in there instead? like the whole center unit
Old Sep 20, 2008 | 10:47 AM
spinviper's Avatar
spinviper
Is the volume control and those stuff on left side of steering wheel, work with your new stereo ??
Old Sep 21, 2008 | 05:17 AM
matix101vz's Avatar
matix101vz
i dont have the voume control on the steering wheel, but if you have it, it works.
you might need to buy an extra harness tho, im not sure.
Old Oct 24, 2008 | 11:00 PM
carjnkie22112's Avatar
carjnkie22112
Default Pioneer Avic F700BT bypass
I just bought one a 2 weeks ago, i might do the Avic f700bt bypass from avic411
Old Oct 25, 2008 | 08:11 AM
Get_Zwole's Avatar
Get_Zwole
what the heck happened to your console? other then that looks awesome love the blue conversion matches well.
Old Nov 9, 2008 | 12:40 AM
t1m1t's Avatar
t1m1t
wow, looks awesome! im actually looking to get the same headunit.
did you just buy the headunit, harness, and dashkit? im thinking about buying the easy plug-and-play harness (dont really care for the bypass), but i dont know if that works with this unit of not. are you running stock speakers also?
much appreciated if you could answer the couple questions
Old Nov 9, 2008 | 10:12 PM
imdelusinl's Avatar
imdelusinl
hey, how did you do the different colors on the gages and the A/C controls?
Old Nov 13, 2008 | 06:43 AM
imdelusinl's Avatar
imdelusinl
nvm, found it, sorry guys.
