AVIC-D3 Navi Problem (Facing Wrong Direction...)
Old Oct 13, 2008 | 10:27 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Default AVIC-D3 Navi Problem (Facing Wrong Direction...)
So I have recently been noticing that the navigation on my Avic d3 isn't working how it should. The arrow that points in the direction that I should be driving always seems to be slowly changing directions.
The "arrow" moves the correct way on the road and in the correct direction, but sometimes the arrow will be pointing sideways, or sometimes backwards, and when it points backwards, the computer assumed I am heading that way and laggs terribly!!!
I have no idea what the problem could be???
Anyone care to chime in? It is bugging the hell out of me!! I hate having to modify my current location 3-4 times during each trip just so I am facing the right direction.
Any help is greatly appreciated, Thanks!
Old Oct 14, 2008 | 05:17 AM
My350P's Avatar
My350P
Check here: http://www.avic411.com
My guess would be something dealing with your gps antenna, possibly bad location/signal, but if it worked fine previously that wouldn't make sense.
Old Oct 14, 2008 | 10:00 AM
M3ANMACHINE
Bump, any other ideas??? I'm going to try to reset the system today and see if that helps.
Old Oct 14, 2008 | 01:05 PM
Done Deal DR's Avatar
Done Deal DR
I have the same problem right now with my D2 which also provides my XM radio signal. According to the D2, the signal levels are good for both the XM antenna and NAV antenna. When I get some time I'm going to tear my Z apart again and rewire the NAV antenna to the same place I have my XM radio antenna, which is inside the rear strut bar cover (do an antenna on either side). My NAV antenna is currently inside my dash near the 3 gauge cluster and worked perfectly for months, I think it may have just been turned sideways by accident but we'll see.
Old Oct 14, 2008 | 01:18 PM
cracka350z's Avatar
cracka350z
just turn the screen around till its facing the right way
Old Oct 14, 2008 | 02:19 PM
Done Deal DR
cracka's got jokes!
Old Oct 14, 2008 | 04:29 PM
M3ANMACHINE
Old Oct 14, 2008 | 04:30 PM
M3ANMACHINE
Let me know how that goes. My antenna is currently on the magnetic sheet on the passenger side corner of my dash.
Old Oct 14, 2008 | 04:33 PM
kham25's Avatar
kham25
On the Navi Screen do you see a East West North South icon?
Old Oct 14, 2008 | 04:42 PM
kham25's Avatar
kham25
I had the same problem your refering to when i got my eclipse navi.. Pissed me the **** off but after i played around with the system that East West NS icon button took care of it!!!!!!!
Old Oct 14, 2008 | 05:02 PM
M3ANMACHINE
Yes i do have the icon, but all that does is change the map to either, the direction your car is heading, or facing north... or am I missing something??
Old Oct 14, 2008 | 06:16 PM
orgasm_donor's Avatar
orgasm_donor
How is the signal strength? You can check this in the GPS system settings. If it is very poor you may need to relocate your antenna. Outside is optimal if you can do it.
Old Oct 14, 2008 | 08:34 PM
matix101vz's Avatar
matix101vz
it might have to do with the wire attached to the reverse light, i have a f700bt and i had to attach a lead from the unit to one of my reverse lights so the avic knows when im going foward or backwards, maybe that came losose or something ... just a guess
Old Oct 14, 2008 | 09:10 PM
M3ANMACHINE
The signal strength is showing 3 bars along with 7 satellite symbols. It is also saying that the surface the antenna is located on has a lot of vibration... Any ideas?
Old Oct 16, 2008 | 09:24 PM
M3ANMACHINE
bump...
Old Oct 16, 2008 | 09:52 PM
orgasm_donor
3 bars is not much. Can you try and relocate the antenna temporarily? Do a test to see if it works elsewhere.
Old Oct 17, 2008 | 01:07 PM
M3ANMACHINE
I'll try. It sounds like there is something sliding around inside the passenger dash when I take turns... I have a feeling that it's something that has to do with the GPS. Now I just gotta figure out how to take the passenger side dash apart.....
Old Nov 25, 2008 | 05:07 PM
M3ANMACHINE
Does anyone who has the D3 installed know if there is some sort of "box" that came with the HU? If so, where did you have it installed/mounted? I believe that is what is sliding around in my dash and also the reason for the direction change...
Old Nov 25, 2008 | 05:26 PM
orgasm_donor
There is no 'box' for this unit...unless you have bluetooth?
Old Nov 25, 2008 | 08:20 PM
M3ANMACHINE
hmmm, no bluetooth. I'm stumped as to why everytime I take a turn something slides left and right. And the arrow starts facing some other random direction other than where i'm actually going...
