need some help pioneer AVH-P4000
Old Oct 24, 2008 | 02:46 PM
Tomek350Z's Avatar
Tomek350Z
Default need some help pioneer AVH-P4000
ok well my headunit works fine and always did
except now when i go to plug my ipod into it it reads error 11- which i checked in the manual and it states a communication failure. it says to disconnect it then plug it back in, and reset the ipod, well i do and no matter what it reads error 11, the ipod will sit there and charge but it never reads pioneer-ok to disconnect anymore
wtf it is really pissing me off
i have the AVH-P4000, someone please give me something, im really mad because all of a sudden it doesnt work, the dvd,radio, work all fine
Old Oct 24, 2008 | 09:20 PM
orgasm_donor's Avatar
orgasm_donor
Have you tried a different Ipod? Have you tried resetting your Ipod? Sometimes they get 'stuck'. If I remember correctly you need to press the menu button and the play button at the same time for like 10 seconds or more.
You could also try resetting the deck. I think there is a small reset button that you can press near the volume **** on the face of the deck. Use the tip of a pen to press this button.
If neither of them work you need to try another Ipod. If another Ipod works then your Ipod is pooched. If another Ipod doesn't work...warranty the deck time!
Old Oct 24, 2008 | 09:54 PM
burner's Avatar
burner
I had this same problem with the unit in my Z. I had to buy a new Pioneer iPod cable (my old one went bad) and reset my iPod, and it started working fine after that.
Old Oct 24, 2008 | 11:09 PM
Tomek350Z's Avatar
Tomek350Z
wow good to hear, i thought of that to because occasionally it would work and then it would, i don think its the deck itself because the DVD,radio, work fine, except for the connection with the ipod, thanks for the help, hopefully itll work, because i bought the unit mainly for the ipod and its pissing me off having to deal with the problem
hey burner where did you buy the old connector and the new one, because i bought the one that i have now off ebay for pretty cheap so i think that has to do with it, this time i bought it from a different seller for a more expensive price
jlb
Oct 15, 2017 05:10 AM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
rouxeny
Audio Builds
63
Sep 27, 2009 01:56 PM
