Problem with Navigation! please help.
Old Nov 1, 2008 | 01:05 AM
Everybodywildou's Avatar
Everybodywildou
Default Problem with Navigation! please help.
I'm not exactly sure which section to post this on, but I have a problem with my stock nav. It seems as though it isn't getting power and doesn't want to turn on when the car is turned on. I don't even hear the DVD rom boot up nor can I eject the DVD. So I know its not getting power.
Does the Nav get power from the headunit? Could the problem be my PAC that installed for my aftermarket amp? HELP PLEASE!
Old Nov 8, 2008 | 04:45 PM
Everybodywildou
bump. come on guys. It turns on periodically so I know its not totally dead. But come on whatever happened to forum input and help?
Old Nov 8, 2008 | 05:31 PM
kevincat's Avatar
kevincat
i think i know what your problem is. it happen to me a month ago. the nav screen wouldnt turn on sometime it takes a while to turn on. i also got a pac switch. no the nav dont get power from the bose hu. i just cant quite remember what i did to fix it. once i remember i post it up. for now i think you got a loose wire in there somewhere
Old Nov 8, 2008 | 10:18 PM
orgasm_donor's Avatar
orgasm_donor
If your Nav DVD player is broken I have one available if you need it. PM me if you are interested.
Old Nov 8, 2008 | 10:59 PM
kevincat's Avatar
kevincat
yeah i remember what i did... i disconect the cable that is connected to the door and the board. since my motor keep breaking i have to unplug the power to the motor and after a while my nav thought that my nav door is close so it wouldnt turn on. so i just unplug the flex cable.
sounds confusing but it really isnt
is your nav door still working?
Old Nov 9, 2008 | 07:37 AM
Everybodywildou
I actually have an 03 that doesnt have an automatic door. It's a manual. But I'm pretty sure it isn't the door because I don't even hear the dvd-rom boot up sometimes.
I think it has something to do with how cold it is. It happened to me once though in the summer and it came on after about 10 minutes of driving. I didnt think much of it cause it continued to work after.
Old Nov 9, 2008 | 12:52 PM
Spike100's Avatar
Spike100
It sounds as though the DVD player is what is broken in your Nav System. That’s a common problem, and probably requires a complete replacement of the entire OEM Navigation unit.
You can see why a mechanically-dependent navigation system (such as this DVD-based device) is so weak. If you do need to replace the navigation system, go with an aftermarket product. It will cost less, be much more reliabilty, and provide far superior performance.
--Spike
Old Nov 9, 2008 | 01:09 PM
Everybodywildou
--Spike
Thanks for the reponse spike. But how come you say that it will probably require a replacement of the entire nav unit? Unless you mean the dvd player alone? Is the dvd player also the brain of the unit?
Old Nov 9, 2008 | 01:43 PM
Spike100's Avatar
Spike100
If your Nissan dealership does the repair of the OEM GPS unit, you will get an entire replacement. That’s how they do the repair. The DVD player is only part of this, but the dealership cannot evaluate individual components and their interaction. Their safe repair is a complete replacement (and I would do the same).
If you need to repair your OEM GPS device, I recommend looking at aftermarket solutions. Avoid systems using DVD-based and HDD-based navigation. Choose a system that is ROM-based (using flash memory and no moving parts) since that provides better performance and reliability.
--Spike
Old Nov 17, 2008 | 09:24 AM
Everybodywildou
--I definitely will do that spike. Especially since my bose HU skips all the time in cold weather. Thanks for the advice. But for now I was hoping there would be someone that had this same problem that could help me trouble shoot it.
I would buy a new HU now, but my Xterra is in dire need of some tires.
Old Nov 17, 2008 | 05:11 PM
orgasm_donor
Not to spam here but I have a fully functional '03 OEM DVD/Nav unit for sale if you need it. PM me and let me know if you are interested. Not looking to make a ton of money as I just want to help another Z-guy out.
Old Nov 30, 2008 | 09:21 PM
Everybodywildou
I guess you can PM me what you would like for it. And how much just for the brain/dvd player.
Old Nov 30, 2008 | 10:34 PM
Everybodywildou
Do you guys have any idea if there is a fuse or relay for the Nav? It seems to turn on every once in a while so its not totally dead. Give me ideas or input please.
Old Dec 15, 2008 | 10:57 PM
Everybodywildou
Okay so it works when the weather is warmer but when its cold it doesnt work? Any fix to this?
Old Dec 17, 2008 | 01:38 PM
gmic350z's Avatar
gmic350z
just replaced my fact nav with aftermarket.ive got an 03 z and had same exact symptoms for a while and one day it had no power at all.went to stealership and took everything apart and said oh ya its not covered under your extended warranty and cost me 200.so i jst went and bought nav accesory for my aftermarket hu and a touch screen and works 100 times better than stock,does so much more stuff..
Old Dec 22, 2008 | 09:51 AM
Everybodywildou
Do you have the bose system? If so, how does it sound with the aftermarket headunit? I'll probably be going this route. I'm just mad that I have to do this you know? Electronics on Nissans in general suck the big one.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
