need help wiring lock/unlock for alarm
Old Nov 18, 2008 | 07:08 PM
KarenZ's Avatar
KarenZ
Default need help wiring lock/unlock for alarm
Hey guys i am attempting to wire in the alarm right now...
the wires i have are
purple - lock - pin 50 - black connector
yellow - unlock - ping 44 - black connector.
I need to know whether to send it a positive signal from the alarm or a negative signal..
HELP PLEASE!!!!!!
thanks
Old Nov 18, 2008 | 08:04 PM
jdmteg2nv's Avatar
jdmteg2nv
I think its negative signal and the unlock wire requires a double pulse
also don't know what year your z is...but on my 03 I had to go into the door for the lock wires...and get it right at the lock module...don't know if its the same for later years
let me know if you need anymore help..just did mine a week ago
Old Nov 18, 2008 | 08:20 PM
KarenZ's Avatar
KarenZ
how were you able to run the wire through the door? if you dont mind me asking... i have come to the same conclusion of doing that as well. but we are having a heck of a time trying to route the wiring
Old Nov 18, 2008 | 09:54 PM
KarenZ's Avatar
KarenZ
ok so i still cant get it to work...
this is how i have it wired up..
red at door goes to a triggered ground that locks
blue at does goes to a triggered ground that unlocks
however i am having no luck getting it to work...
if i just ground the red wire it will lock right away
same goes for the blue wire..
however w/ the alarm set up when i hit the lock/unlock on the door it always trys to lock it..
Old Nov 19, 2008 | 08:51 AM
jdmteg2nv's Avatar
jdmteg2nv
what kind of alarm are you putting in?
did you meter the lock wires to make sure that the alarm is sending out a negative pulse?
also certain alarms don't send a strong enough signal to trigger the lock module..you might have to hook up a relay to increase the signal strength...
did you figure how to run the wires through the door..or still need help?
Old Nov 19, 2008 | 03:46 PM
KarenZ's Avatar
KarenZ
so as a conclusion the clifford avantguard install instructions suck severely..
they have this double pule wire coming out of the system but did not say how.
we were able to tap into both the ground for the lock and unlock. and then had to take off the door panel and then route it through the factory harness. ultimately drilled the plastic connectors to allow it to pass through for a seamless install..
at this point we are now just soldering all the connections and buttoning her up ...
Old Nov 19, 2008 | 05:56 PM
jdmteg2nv's Avatar
jdmteg2nv
glad to hear...usually you have to activate the double pulse in the unlock wire..u can do that with the valet button...or easier method use the bit writer if you have one...let me know if you have any more ??'s
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
