New audio build... what else do I need?
Old Nov 30, 2008 | 05:13 PM
arumndark's Avatar
arumndark
Default New audio build... what else do I need?
Hi folks! The time to replace the stock stereo system has come.
Here is what I'm planning:
Pioneer AVIC-F700BT for the head unit (no XM for now, maybe later)
Infinity Basslink to put in the hole behind the driver's seat
Infinity Reference 6022si speakers to replace the front door speakers
Beyond speaker wire (12-gauge?) and standard connectors (figured I'd get one of those "kits" that come with a bunch, since I really don't have any of that sort of thing around the house anymore)... what else do I need?
Special connectors for the sub/speakers?
Special wires for the sub (never installed one )
Anything extra to mount the sub behind the driver's seat? (car doesn't have the Bose setup)
Mounting for the speakers in the doors? Spacers needed with these ones? If so, where can i get them/are they called anything special?
And I suppose the sub will need some power - preferred cable for that?
Thank you folks.
Old Nov 30, 2008 | 06:24 PM
arumndark's Avatar
arumndark
Will this:
http://www.amazon.com/StreetWires-Po...8101692&sr=1-1
work out OK for wiring up the Basslink?
And does using the stock speaker mounts eliminate the need for spacers?
Old Nov 30, 2008 | 10:27 PM
orgasm_donor's Avatar
orgasm_donor
That'll work fine.
The stock front speakers are mounted in such a shallow spot that you will most likely need 1/4" to 1/2" spacers.
Old Dec 1, 2008 | 11:20 AM
arumndark's Avatar
arumndark
Sounds good!
Also, do I want/need the Metra kit? Is that just a trim piece to go around the outside of the face?
Old Dec 1, 2008 | 11:53 AM
Get_Zwole's Avatar
Get_Zwole
yeah you need one also gonna need an amp for the components dont know if you already have one or not.
Old Dec 1, 2008 | 07:08 PM
orgasm_donor
What he said^^
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
ZEyeDoc
Dec 5, 2002 03:52 AM
