amp help
Old Dec 6, 2008 | 10:37 AM
spdtckts's Avatar
spdtckts
Default amp help
I tired searching but it yielded no results. so here is the problem i have everything hooked up as it was described and as i have done it many many times before and had no problems.
the amp is getting power, the protect light comes on but the power light does not. and then that it is all it does. no sound no static nothing. its almost like its not connected at all. the HU is Kenwood DVX6019 DDin the amp is a soundstream 360watt and the subs are Rockford P1's
any suggestions?
Old Dec 6, 2008 | 10:43 AM
djwatts's Avatar
djwatts
i had this problem with a previous amp man, and its not good your amp is fried, when i ordered mine it got sent like that so i had to return it. most likely on yours you either had neg touch pos or just a defective amp
Old Dec 6, 2008 | 11:08 AM
spdtckts's Avatar
spdtckts
is there any other possibilities. bad wires blown fuses? anything?
just want to get an idea if i should try anything else before buying a new amp
Old Dec 6, 2008 | 11:02 PM
orgasm_donor's Avatar
orgasm_donor
Well, if you have a simple test light you can see if the amp is getting both power and remote turn on power from the deck. Remember to double check your ground to the chassis as this is often an overlooked problem. If you've got good power and ground then it may be your RCAs. Try running another set to test them.
Failing the above, try another amplifier.
Old Dec 7, 2008 | 03:06 AM
spdtckts's Avatar
spdtckts
thanks ill try that today and if nothing ill be looking for a new amp.
Old Dec 7, 2008 | 05:40 AM
Z1NONLY's Avatar
Z1NONLY
I would also connect the amp ONLY to power, ground and the turn-on lead.
(It may think there is a problem with the load, and then try to "protect" itself from the speakers.)
If it works (comes out of "protect") without the speakers connected, I would check the speaker connections and speakers.
Old Dec 7, 2008 | 11:50 AM
spdtckts's Avatar
spdtckts
alright i didnt get a chance to try orgasms idea because the army believes in selling head units and speakers but is against cables and accessories you need. as soon as i get a chance ill try this and let you all know
thank you!
Old Dec 8, 2008 | 03:30 PM
spdtckts's Avatar
spdtckts
ok so i reconcected the ground wire (it was loose) checked all the other wires. and now the protect light went off and now i get no response at all from the amp...so i take it i fried it?
Old Dec 8, 2008 | 03:56 PM
orgasm_donor
no lights at all? My money is on your power then. Your fuse may be blown. Double check the fuse - if its an AGU glass fuse then it may be disconnected inside where you can't see it. Wiggle it around and see if that helps...if it does, replace the fuse right away. I have seen this all to often. You need a test light brother! $2-$5 at walmart for a basic one.
Old Dec 8, 2008 | 04:04 PM
spdtckts's Avatar
spdtckts
i live in germany there is no walmart i know its crazy. the fuse in the amp is good ill check the AGU fuse. if its a cable im screwed 10X over cuz there is even less places to get a cable like that long and thick
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
