WTF,, no sound in rear speakers,, avh4000
Old Feb 2, 2009 | 05:28 AM
geeksquadryder's Avatar
geeksquadryder
Default WTF,, no sound in rear speakers,, avh4000
completed the install,,,,,, a lil difficult wit the factory navi system but stil managed to do it in under 5 hours... never turned volume up.... later that night i realized no sound from rear panel speakers.... used metra kit and the pac oem harness since i am keeping the facotry set up for at least after summer...... where did i go wrog
Attached Thumbnails WTF,, no sound in rear speakers,, avh4000-100_0363.jpg   WTF,, no sound in rear speakers,, avh4000-100_0369.jpg
Old Feb 2, 2009 | 05:54 AM
ohfourzee's Avatar
ohfourzee
check your wiring harness to make sure you have + and - for both left and right rears
Old Feb 2, 2009 | 12:15 PM
orgasm_donor's Avatar
orgasm_donor
I would say thats a good thing. Rear speakers in these cars are not only garbage, but their placement is horrid. I say keep it that way and upgrade your fronts.
Old Feb 2, 2009 | 02:45 PM
Get_Zwole's Avatar
Get_Zwole
Originally Posted by orgasm_donor
i would say thats a good thing. Rear speakers in these cars are not only garbage, but their placement is horrid. I say keep it that way and upgrade your fronts.
+1000000000
Old Feb 3, 2009 | 08:14 PM
Schloem_Z_Gnome's Avatar
Schloem_Z_Gnome
Man I have this same problem. There is audio, it's very faint though. I had it installed by an performance shop who is well accredited. I didn't notice it for a while and I had suspicions they messed something up. I am an Avionics technician in the Air Force so I know a few things about wiring so I took everything apart to inspect their work. I would have personally used different splices, I probably would have used solder-type environmental splices but aside from that everything was hooked up correctly. I was pretty baffled but said oh well. Possibly an issue with the internals of the AVH-P4000? I am unsure. Is there anyone else who has had this issue in the past that has any input? I'd like to know as much as the OP! OP if you find anything out, PM me!! Later
Old Mar 4, 2010 | 09:26 AM
snowboarder599's Avatar
snowboarder599
Originally Posted by Get_Zwole
+1000000000
You don't really need them for the car to sound good! My car speakers bump without the rears... If you want better sound, I would suggest putting in an amp, and maybe some subs!
Obadabot
Jun 18, 2023 11:31 PM
