AMP Not Working Help
Old Feb 17, 2009 | 06:02 PM
hackermb's Avatar
hackermb
Default AMP Not Working Help
Ok so I just got a pioneer avic-f700bt navi and hooked it up to a kicker ZX750.1 amp which is hooked up to 2 Kicker CVR 10's. I have had the head unit and amp hooked up for a few days and the amp seemed to be turning on right, red light was on. After my box finally arrived I went to hook up the subs and all of a sudden the amp wouldn't turn on anymore.
Everything is hooked up as shown on kickers website
http://www.kicker.com/sites/default/...0f01%20web.pdf
I checked all the power and REM and everything has the correct voltage.
So here is the weird part. If I take the left Input RCA and plug it into the Left Output RCA the amp turns on and the subs work a little bit, but aren't right. Also the amp will keep turning on and off when setup this way.
All equipment is brand new.
Any suggestions on what the problem maybe?
Thanks for the help
Old Feb 19, 2009 | 04:12 AM
hackermb's Avatar
hackermb
Ok I don't think its the amp anymore but the way I setup the two 10's.
I setup in series 2 2 ohm Kicker CVR 10's and zx750.1 monochannel Kicker amp.
So I have from the +AMP to the red/wh dot on the first sub. Then blk/wh dot to solid red. Then the solid blk to the red/wh dot on the second sub. The blk/wh dot to the solid red and finally the solid blk back to the amp -. I believe this is exactly how Kicker said to set it up in their manual but when I hook it up to my brother's amp no sound comes out.
Any suggestions?
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
