anybody put aftermarket 10 inch sub behind driver seat?
Old Sep 8, 2003 | 08:25 PM
chia's Avatar
chia
Default anybody put aftermarket 10 inch sub behind driver seat?
JUST WONDERING IF PEOPLE SCUESSFULLY INSTALLED A AFTER MARKET (NON-BOSE) 10 INCH SUB BEHIND THE DRIVER SET.
I found the big hole supposally for a 10inch sub, but placed a JBL W0 10 inch sub in there and the hole seemed larger than the sub. I have doubts if I buy a 10 inch sub will it fit right. I'm sure i can drill new holes. There is a lot of room back there, maybe too much room for a single sub.
I was thinking about getting a Rockford Fosgete HX2 for my JBL 600 watt mono amp. Maybe the amp will fit inside that area where the sub will be.
Old Sep 8, 2003 | 08:30 PM
wren57's Avatar
wren57
simple answer: itll fit but sound like crap
Old Sep 8, 2003 | 08:54 PM
chia's Avatar
chia
yea, thats what i'm afarid of. Too much space for the sub. The HX2 needs less than 1 sq ft.
but any bass is better than nothing!
Old Sep 9, 2003 | 01:28 AM
pulpz2's Avatar
pulpz2
I was thinking about putting an aftermarket sub in also. Anybody do this with good results?
Old Sep 9, 2003 | 04:38 AM
FLY BY Z's Avatar
FLY BY Z
Search button, guys. This is so talked about. You can find all you want to know and more just by hitting the search button. It is less work for you and less redundant stuff for everyone else. Try it. It works great!
Old Sep 9, 2003 | 09:39 AM
blackbase's Avatar
blackbase
I recently installed a 10" alpine sub in the stock spot and when it hits really hard the metal plate that holds the sub vibrates and really kills the sound, and that's off a mono 500w.
Today I took it down to a custom shop for a fiberglass job of the area. The place is charging me $500 for the job and say they may have to keep over night .
I'll let you know how it turns out.
Old Sep 9, 2003 | 12:18 PM
nmilsaps's Avatar
nmilsaps
I put in an MB Quart 10" sub that i had in that space, with the amp behind it. To me it sounds fine, alot better than nothing at all. It's nothing booming. The sub was smaller than the opening though, so i only got to put two bolts in the exiting holes on one side, and the other side had a C-shaped air space. at first it would rattle when the sub would hit up against the plate, so i bought some sealant and made a seal around the entire opening. now there are no rattles at all and it sounds good.
Old Sep 10, 2003 | 10:35 AM
zand02max's Avatar
zand02max
I would not put it behind the seat, you are better off getting a single 10 or a pair, and making a custom box under your strut bar. Here is a pic of mine installed.
Attached Thumbnails anybody put aftermarket 10 inch sub behind driver seat?-imgp1378.jpg
Old Sep 10, 2003 | 10:36 AM
zand02max's Avatar
zand02max
Heres a pic of the cover
Attached Thumbnails anybody put aftermarket 10 inch sub behind driver seat?-imgp1377.jpg
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
