My Install
Old Mar 19, 2009 | 07:55 PM
sincere85's Avatar
sincere85
Originally Posted by adamtaylorpcb
subs there period is flashy.
want not flashy. dont get subs that molest your head
I wouldnt say the location is flashy. It can be toned down (see pic) I love this one. It was created by a member here, but the one pictured wouldnt work with 12s. Its also a pretty much useless space for me that I dont use. Plus, I wanted to keep my trunk and cargo net for storage issues. So, this box was best suited to satify all my requirements which where: more airspace, more depth, more trunk space, better sub selection, and the ability to accommodate 12's. I was considering 10's but most under strut boxes really lack in the airspace department which really limits ur selection of higher powered 10's if u r following the recommended box volumes.
Im considering covering it in vinyl in the future. Plus, I dont mind subs that molest my head.
Old Mar 19, 2009 | 11:16 PM
Vishal1's Avatar
Vishal1
wow that one is really clean. i have always wanted to try a set of 10's but never got around to it. well my amp gets here on monday so i will let you guys know if the Q sounds a little better. if not i think ill just gut the trunk out and make my box deeper and for dual 12's and get another amp and upgrade my electrical so it can handle 2 1608d's with my Zeus. hopefully it wont come down to that...
Old Mar 20, 2009 | 12:05 AM
Peak350's Avatar
Peak350
If it makes you feel any better I just spent 4 hours putting sound deadening all through my trunk area. No internal rattles....sounds perfect...in the car.
Rear bumper must have 1000 little things that rattle and I really don't plan to take it off to deaden the stuff outside the car. Its almost sad because I can't tell when it sounds like ***, and I know I'll embarrass myself one day, especially with how little bass escapes the car now with the windows up.
Old Mar 20, 2009 | 11:58 AM
Vishal1's Avatar
Vishal1
lol, it took me about 3 nights 3 hours each night to deaden my car. i was very **** about it and made sure that every inch of the trunk AND the hatch was deadened, as well as the doors. i was going to deaden the roof and the floor as well, but i thought about it and realized it would only block out road noise, which i wouldn't hear anyway from my music being so loud. i ordered 72 sq ft of edead and i have a good amount left over, its more than i know what to do with. my bumper doesn't rattle at all, just a tiny bit of rattling coming from the hatch door, but i think its the plastic paneling on the door itself. who knows, maybe when i get my other amp and feed my sub more wattage, it might rattle more. hopefully not...
Old Mar 20, 2009 | 03:12 PM
Peak350's Avatar
Peak350
My sub is rear firing so that could be a large portion of it.
I moved fast when working last night (trying to hurry) had taken it apart before so knew right where to grab the panels, and took the "make the panel heavy" approach and just put an extra layer next to areas I found too time consuming to cover. I can always go back and do it later. I also put deadening in large unbraced areas of panels (even small panels) and it made a huge difference.
I haven't done my doors yet, just pulled the drivers side panel to get started now (after spending 4 hours getting my amp installed and wired...hope I don't have to take the dash apart again). This is the 6th time I've had all this **** apart so its becoming routine now
Old Mar 20, 2009 | 07:59 PM
Vishal1's Avatar
Vishal1
lol i see.... what deadner are u using? i have only pulled the Z apart once, but it was the ENTIRE car. i have also deadened the walls of the car as well. i love how it sounds on the inside. for some reason i absolutely hate taking the dash apart too. its not that its hard its just annoying as hell. but unfortunately i will have to when i install my navi unit.
Old Mar 20, 2009 | 10:07 PM
Peak350's Avatar
Peak350
Edead 45 mil.
I got 3/4 the way done with my drivers side door (being careful not to cover a nut, bolt, or whole, and said F*** it. Put everything together, slapped a huge piece on the passenger door covering all the bolts etc, cut the screw holes for the door panel, and assembled that side.
I figured if there were rattles I'd fix them later, since I'm not running THAT much power it shouldn't be an issue, and I heard no rattles.
Old Mar 21, 2009 | 03:47 PM
Vishal1's Avatar
Vishal1
Edead 45 mil.
lol thats funny i did the same thing. i think i will just double up on my hatch door...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
