Wiring amp to sub question
Old Jul 1, 2009 | 11:29 AM
Hybrid90's Avatar
Hybrid90
Default Wiring amp to sub question
Ok I have question..
I have a spare MTX Thunder 302 amp http://www.realmofexcursion.com/ampg...X_Thunder_302/ and also an ol'school JL 12w6 http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf in a sealed box.
So if I was to bridge the amp into a final load of 4ohms @ 300watts, how do I wire the 12w6 sub (which is a DVC 6ohm sub) so it can push out the most power without harming amp or sub? What's the most logical wiring of both amp and sub? Thanks in advance!
Old Jul 1, 2009 | 11:35 AM
stoffius's Avatar
stoffius
i've always wondered what chocolate from budapest taste like
Old Jul 1, 2009 | 11:39 AM
doug's Avatar
doug
I would give you advice.. but the fact that you can't find the Audio Forum means that you probably wouldn't be able to follow the simple instructions i give you
Old Jul 1, 2009 | 11:40 AM
phreaktor's Avatar
phreaktor
Design Engineer
+1
Unless the amp is 2 ohm stable in mono, you should to run it at 6 ohms which means simply running +/- from one voice coil straight to the amp.
Alternatively, you could wire the coils in parallel and show the amp 3 ohms and this should be ok as long as you don't overdrive the rail voltage into clipping. Parallel is + to + and - to - then +/- out to the amp.
Old Jul 1, 2009 | 11:44 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Dual 6 ohm sub = 3 ohm or 12 ohm configuration. Shoot for 3 ohms, your amp should handle that.
Wire + to + on the sub and connect to + on the amp.
Wire - to - on the sub and connect to - on the amp.
Done.
Now, remember to post in the audio forum in the future rather than OT.
Old Jul 1, 2009 | 11:49 AM
Hybrid90's Avatar
Hybrid90
Goddamnit! Keep forgetting we have an audio forum.. guess I'm so used to posting on the lounge... my bad and thanks for all teh suggestions!
Old Jul 1, 2009 | 11:51 AM
stoffius's Avatar
stoffius
you're welcome
Old Jul 1, 2009 | 11:52 AM
phreaktor's Avatar
phreaktor
Design Engineer
They aren't "suggestions", they are LAW. Ohm's Law to be exact.
Old Jul 1, 2009 | 11:59 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Jul 1, 2009 | 01:33 PM
Hybrid90's Avatar
Hybrid90
So as long as the ohms on the amp is higher than on the sub.. the amp won't overheat and die out on me? OR is it the other way around?
Old Jul 1, 2009 | 01:47 PM
Never heard of Ohm. Is he in the forced-induction forum?
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
