2 speakers, one channel @ 2 ohms.... watts?
Old Jul 5, 2009 | 07:25 PM
chrisl113's Avatar
chrisl113
Default 2 speakers, one channel @ 2 ohms.... watts?
quick question, i forget my audio details, im going to order 2 8" subwoofers and my infinity amp can supply 300 watts @ 2 ohms. the subs are svc 4 ohm, so ill wire them in 2. question is, when you add another sub does the wattage needed double too?
if so, im getting the tang band's, 150 watts rms
http://www.parts-express.com/pe/show...number=264-854
if not, ill get the dayton references that are 280 rms
http://www.parts-express.com/pe/show...number=295-456
most of me wants to say the rules of resistance blah blah blah says the wattage stays the same, just the resistance changes, so that would mean that the daytons will work, but i dont want to take the chance that i need twice the power and and my amp wont push the "subz", thats the worse case scenario! thanks
Old Jul 5, 2009 | 08:53 PM
Power is measured at a specific resistance.
150 watts @ 4 ohms
300 watts @ 2 ohms
Arithmetic allows you to decrease resistance to infinity increasing power to infinity. Unfortunately electronics does not work that way. At some point the amplifier will not handle the deceased load.
Old Jul 5, 2009 | 10:17 PM
chrisl113's Avatar
chrisl113
ok, your talking about the amplifier, right? i know amps make more power with less resistance, my wasnt my question. thanks though
Old Jul 10, 2009 | 11:12 AM
chrisl113's Avatar
chrisl113
bump for better answer please? still waiting on buying these!
Old Jul 10, 2009 | 11:26 AM
StreetOC192's Avatar
StreetOC192
If your amp does 300 rms into a 2ohm load, then getting the 2 TB single 4ohm voice coil subs and wiring them parallel to a 2ohm load will allow your amp to produce its rated 300 rms watts.....thereby sending 150 rms watts to each sub.
Old Jul 10, 2009 | 08:45 PM
chrisl113's Avatar
chrisl113
perfect, just want i wanted to know. the parts express guy tried to say the daytons could be powered just fine off of 300 watts, which is true to an extent, but i really dont want to use bass boost (since it defeats the purpose of buying 8's) and i prefer to over power my speakers with clean, non distorted power than underpowering and adding distortion. but what cought my attention is he said the tang bands would sound better in a vented .50 cf box, and im using a sealed so he said the daytons would be even better. plus, the daytons have less distortion. so know im wondering if the daytons are the way to go...
Old Jul 11, 2009 | 04:14 AM
StreetOC192
Maybe me or someone else could give you some guidance.....
Do you have an enclosure already or one in mind?
what is your budget?
What is the rest of your system?
What type of music do you listen to?
Where will these be mounted?
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
